Sammy engine conv. Questions
  • 1722 Views
Offline tipover
  • 422
« on: October 21, 2007, 12:52:58 PM »
Where do you mount the Sidekick ECM in the samurai. On the drivers side firewall in the passanger compartment like the stock Sidekick? how did you mount it.  Has anyone put it in the stock Samurai location?
Also can i use the stock sammy radiator with the 1.6 8v conversion?  will it overheat?
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline ROSS
  • 1412
Re: Sammy engine conv. Questions
« Reply #1 on: October 21, 2007, 04:39:31 PM »
mount it in the same place as the other passenger side behind the glove box.
radiator is fine. just run the shroud
Offline tipover
  • 422
« Reply #2 on: October 21, 2007, 06:07:38 PM »
Did you make your own harness?  it seems that to do that I would have to extend the wires to the coil and O2 sensor...
Offline ROSS
  • 1412
« Reply #3 on: October 21, 2007, 07:58:13 PM »
I let brent at Trail Tough do it. just plug and play.  well worth the cost
