Castor on Samurai
  • 1958 Views
Offline 88Sammy
  • 68
    • JDM parts
Castor on Samurai
« on: October 22, 2007, 03:48:09 PM »
Currently my Samurai wants to wander from side to side after my SOA.  I took it to the alignment shop and the castor reads 2.4 on one side and the other side reads 2.5.  The factory service manual says it should be 3.3.
I’ve been told by several sources and people that since my caster is a bit low, that could be the cause of the wandering.  I have seen the steel shims on Rocky Road and Lowrange.  They are 3 degrees.  This will put me at 5.4 & 5.5 and should stop the wandering.
Has anyone had experience with using the shims to correct caster and is a little too much positive caster bad?
Offline 88Sammy
  • 68
    • JDM parts
Re: Castor on Samurai
« Reply #1 on: October 23, 2007, 11:39:04 AM »
Here are some pictures of the steel shims:
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #2 on: October 23, 2007, 11:50:30 AM »
More caster is definitely better than less, put them in and see what you get.
Student of Now Master of Then
