camber bolts
  • 14 Replies
  • 3981 Views
Offline 92Sidekick4x4
  • 1456
camber bolts
« on: November 12, 2004, 12:56:39 PM »
hey everyone,
in a few days im planning on installing my spring spaccers, wondering what kind of camber bolts to get?  are there good ones and bad ones? etc. what do they usually cost?
Re: camber bolts
« Reply #1 on: November 12, 2004, 02:44:15 PM »
I Did alittle search
12   ZUKIWORLD Discussion Forum / Suzuki Forum / Re: negitive camber.   Sep 15th, 2004, 1:10am
Started by balance | Post by zookiemike
on Sep 14th, 2004, 7:28am, 90Stomper wrote:
camber bolts will fix this easy, around $20 on ebay, easy to put in and adjust and should fix 100% on a 2" lift, i still have a bit of prob with a 3" lift.
There about $15 dollers from car quest.
 Ã‚
« Last Edit: November 12, 2004, 02:44:48 PM by trickker »
Re: camber bolts
« Reply #2 on: November 12, 2004, 02:50:25 PM »
Or here
97TRAKIN
Member Contributor
 Re: Tracker Spring Spacer Lift (w/pics)
« Reply #21 on: Aug 24th, 2004, 7:58am »  Quote  Modify
on Aug 9th, 2004, 2:41pm, Chief wrote:
And where is one to get said Camber bolts? I have a 1.5" spacer lift on mine, and need the camber bolts!
Carquest carries them $19.75. If they say they don't have a listing for your vehicle in the book ask them if they looked it up in the system. The part # is in the system not the book.
  • 1456
Re: camber bolts
« Reply #3 on: November 12, 2004, 04:17:00 PM »
ok thats great, thanks
Offline chrisvitarasport94
  • 228
Re: camber bolts
« Reply #4 on: November 12, 2004, 06:39:50 PM »
www.specprod.com for application list
Offline 94track
  • 212
Re: camber bolts
« Reply #5 on: November 13, 2004, 02:23:21 AM »
when i installed my 2" spacers i purchased a pair of camber bolts form napa.  With factory tires the camber was way off, after installing my 31's with a 2" backspaced wheel, camber was perfect with only the stock bolts.  Needless to say i returned the bolts.
Re: camber bolts
« Reply #6 on: November 13, 2004, 01:04:38 PM »
   I bought my camber bolts from local auto parts shop for $16.  But I also was able to align mine without them and returned them.
  • 1456
Re: camber bolts
« Reply #7 on: November 13, 2004, 01:23:09 PM »
anmy pics of yer truck? what size BL do u have?
Offline SnoFalls
  • 1358
Re: camber bolts
« Reply #8 on: November 13, 2004, 11:11:21 PM »
I can't see how changing the backspacing would effect the camber ...
Unless the added leverage from the increased track width is now compressing the springs more ...
Offline 94track
  • 212
Re: camber bolts
« Reply #9 on: November 14, 2004, 11:12:42 AM »
i don't think that tires has much to do with the camber, i think that it was the backspaced wheels that added alot of leverage to the front suspension, it was way out of wack with the factory tires but after the new rubber and rims it was perfect, i even had it put on a rack and it was just about perfect.  i have a 3" calmini body lift and more pics soon to come this week.
Offline mbmarkyb
  • 461
    • UK Vitara
Re: camber bolts
« Reply #10 on: November 14, 2004, 05:35:44 PM »
I take it these camber bolts are for the bottom ball joint
Was there talk before of adjusting the top holes out a little to correct this,
Im having simular issues with my 3 inch calmini kit.
Camber causing wheel bearing to go pretty quickly
Markyb (UK)
UK Vitara JLX SE
Offline cj
  • 1276
  • I drive a really big ATV
Re: camber bolts
« Reply #11 on: November 14, 2004, 07:29:48 PM »
I needed a camber bolt on one side with my Calmini 3" to get it right.
Offline mbmarkyb
  • 461
    • UK Vitara
Re: camber bolts
« Reply #12 on: November 15, 2004, 05:37:13 PM »
Has anyone broken camber bolts on there truck??
also do you get any play if you slightly adjust the holes ?
Markyb (UK)
UK Vitara JLX SE
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: camber bolts
« Reply #13 on: November 15, 2004, 06:34:57 PM »
I have talked to a few guys with bigger lifts who have slotted the strut hole then welded a  washer to perminently locate the new position.
I am thinking of taking this a step further and slotting the upper strut mount hole and fabbing in the Chrysler or Toyota style ecentric washer & washer holding device.  Still giving me the ability to adjust for future changes.
I have had many people advise me aginst the camber bolts, saying they break.  I have yet to find anyone who has actually broken one  BUT  I do believe that the camber adjustment bolts would pose a weaker link.
Here is a Screen shot of the Spec prod page.   Looks like top quality stuff.
« Last Edit: November 15, 2004, 07:24:46 PM by whitfield »
Re: camber bolts
« Reply #14 on: November 16, 2004, 08:00:55 AM »
The Speciality Products bolts are also TUV approved
