$500
  • 21 Replies
  • 6918 Views
0 Members and 10 Guests are viewing this topic.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
$500
« on: June 12, 2005, 09:21:36 AM »
If you had $500 dollars (right now) to spend on a stock TrackVit what would you do to it.
I'm thinking a set of A/Ts
Offline SnoFalls
  • 1358
Re: $500
« Reply #1 on: June 12, 2005, 09:52:24 AM »
body lift ($100 or less)
spring spacers ($80)
mini-spool for rear ($100)
used 31x10.50's from some heep ($200)
fluids to make it trail worthy ($20)
Offline echojeff
  • 414
  • Lo que sea
Re: $500
« Reply #2 on: June 12, 2005, 11:28:25 AM »
Does Heather and Nate's lift kit cost that much?
And ok I am new to this.... what fluids enhance trail worthiness? And since you this newbie is still learning, I know about positraction, lockers, but whats a mini spool do for you?  I am really pleased to hear you can get used 31's for that cheap.  ::)  That moves my modification time table up. ;D
95 Kick 4dr JLX.
Offline explosivo
  • 3157
Re: $500
« Reply #3 on: June 12, 2005, 11:58:52 AM »
Add in another $1000 for a 3" lift and Anvil front housing :P
omghi2.us[/url]
Offline 97TRAKIN
  • 600
Re: $500
« Reply #4 on: June 12, 2005, 01:15:17 PM »
No spool in this DD, it's an "04 Tracker.
When I do lift it I'm going with a body lift and no suspention mods what so ever. I had some VERY BAD experiences with my "97 after miner suspention mods.
« Last Edit: June 12, 2005, 01:16:13 PM by 97TRAKIN »
Offline kansascitytracker
  • 335
  • 92 Tracker
Re: $500
« Reply #5 on: June 12, 2005, 04:00:44 PM »
Pioneer XM ready CD deck- $110
XM antenna kit-$45
XM frequency modulator box-$45
One year XM satellite radio subscription-$160=
money very well spent
Re: $500
« Reply #6 on: June 12, 2005, 07:26:54 PM »
Whats the feq. mod box for? or do?
Offline SnoFalls
  • 1358
Re: $500
« Reply #7 on: June 12, 2005, 09:07:01 PM »
oil change, diff fluid change, coolant change, gasoline :)
I got five 32x11.50's today (mounted on 5x5.5 rims) for $50 ... if you scrounge, you can find deals on tires/wheels.
Offline SnoFalls
  • 1358
Re: $500
« Reply #8 on: June 12, 2005, 09:12:00 PM »
yea no spool for a DD.
Are you going to wheel it or you just going for a meatier look?
Offline 97TRAKIN
  • 600
Re: $500
« Reply #9 on: June 13, 2005, 10:48:27 AM »
Let me put it this way, I wheeled my 2000 with the 30 day tags still on it at Paragon. ;), any questions?
Offline SnoFalls
  • 1358
Re: $500
« Reply #10 on: June 13, 2005, 11:07:27 AM »
sry ... had to ask.
some want pavement princess, some want a capable wheeler (and/or prepared for body damage).
what kinda probs? ... spacers and body lift get bigger tires. Lockers make it unstoppable. I've not had any probs with my spacers for cheapo suspension lift. I'm looking to get cheapo spring replacements ... but not *needing* them really.
Your initial $500 question is limiting due to the cost aspect (and I usually figure all costs). If you don't count tires, I guess I'd suggest OME springs, a BL, and ez-locker in the rear.
(It's fun to spend other peoples money :) )
« Last Edit: June 13, 2005, 11:08:34 AM by SnoFalls »
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
Re: $500
« Reply #11 on: June 13, 2005, 12:46:10 PM »
just a correction 5x5.5 means the bolt patteren which would be nessercary to fit on your kick no matter what size the rim. Unless you got a 5 inch tall rim with a 5.5 wide.
Offline adamd
  • 369
  • sofa king we todd it
Re: $500
« Reply #12 on: June 13, 2005, 01:23:39 PM »
2 hookers
'98 kick
3" B/l
30" Mud Kings
  • 335
  • 92 Tracker
Re: $500
« Reply #13 on: June 13, 2005, 01:40:32 PM »
The radio may be "XM Ready" but you still need a frequency modulator box to decipher the satellite signal.
Offline locjaw
  • 2045
  • 22
Re: $500
« Reply #14 on: June 13, 2005, 01:51:01 PM »
2 hookers
steppin up to the fancy hookers  :-/
jason
