suspension
  • 3044 Views
tracker8v4x4
suspension
« on: October 28, 2007, 04:13:54 PM »
does any one know if the front or back springs on a 94 tracker diffrent size if so witch ones bigger and by how much thanks
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: suspension
« Reply #1 on: October 28, 2007, 04:41:08 PM »
The front and rear coil springs are different sizes. The rear is taller than the front. But more importantly they are also different RATES. the fronts are much stiffer than the rear. Rear springs are not stiff enough to hold up the front of the tracker since the rear springs are on a solid axle and the front suspension is independent, which increases the leverage against the springs and they have to hold up the engine as well. Whitfield has even tried using XJ coils up front, but they also were not stiff enough to support the front end.
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: suspension
« Reply #2 on: October 28, 2007, 06:30:46 PM »
Where were you going with this anyway?  Anyone who has looked into the suspension on this knows that they're completely different between front and rear.
1993 4-door Sidekick
4.24:1 t-case
tracker8v4x4
Re: suspension
« Reply #3 on: October 28, 2007, 06:41:57 PM »
i kno the fronts stiffer but i was hopeing they were taller so i coud put them on back and use spacers in front
Re: suspension
« Reply #4 on: October 29, 2007, 01:28:58 PM »
The fronts are a fair bit shorter and much stiffer, something like 350lbs vs 157lbs. I doubt if the suspension would flex at all with front springs on the back.
Re: suspension
« Reply #5 on: February 11, 2012, 12:57:40 PM »
Do you know where I could find a comprehensive list of all the suspension specs on a 93 2dr sidekick???
Re: suspension
« Reply #6 on: February 11, 2012, 02:04:05 PM »
