Oil change via dipstick?
  • 25 Replies
  • 6178 Views
Ira
« on: October 29, 2007, 06:39:23 AM »
Have any of you guys ever used any of those electric gadgets that drain your oil via the dipstick, so you don't have to remove the plug? Also, if you do your oil every 3000, do you have to change the filter every time?
I really want to baby my Track, maybe even change the oil more often, but getting to the mechanic just for this is a real PITA, not to mention the additonal cost of a mechanic.
I was just suspicious whether those devices actually get all of the old oil out.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Oil change via dipstick?
« Reply #1 on: October 29, 2007, 09:07:37 AM »
Dude, get a drain pan, a recycling bottle (a $5, wide-mouth reusable walmart one makes it easy), a roll of paper towels, a socket wrench and a 17mm (i think) socket for the drain plug and just change your oil and filter yourself, the old fashioned way.  You don't really even need a jack with these trucks.
If you're worried about oil spots, get some cardboard and place it under the whole front of the truck when you do it.  Some aluminum foil arranged under the filter can be used to funnel drippings into the drain pan.
Dish soap will clean you up aftward.
Be sure to spread a drop of oil around the gasket of the new filter when you install it, and don't crank it down too hard (or you'll pay for it when trying to remove it next time) and you're good to go.
You're depressing me.
XL-7 front coils
1.5" rear coil spacers
Ira
« Reply #2 on: October 29, 2007, 09:27:41 AM »
I'll see how easily I can get under there.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: October 29, 2007, 09:34:45 AM »
Do you have a skid plate?
XL-7 front coils
Ira
« Reply #4 on: October 29, 2007, 11:44:43 AM »
Nope.
I have a few screwdrivers, though. And a hammer. And a few rolls of paper towels.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #5 on: October 29, 2007, 12:00:18 PM »
Nope.
That and some duck tape will get you a long way.  It's a good starting point.  But you will need a wrench for that drain plug.
Lefty loosey, Righty tighty.
XL-7 front coils
Ira
« Reply #6 on: October 29, 2007, 12:04:54 PM »
HAH!!!!!!
Seriously, thanks for the inspiration and motivation.
I'm not THAT stupid that I can't do an oil change--it's just I didn't want to deal with having to jack her up. I'm the kind of guy that gets on the news the following day for being crushed by car.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #7 on: October 29, 2007, 12:08:16 PM »
Go to sears and buy a small Craftsman set. They are quite inexpensive if you buy a set and the tools are top notch.
« Last Edit: October 29, 2007, 01:20:29 PM by sidekicksrock »
Student of Now Master of Then
Offline Carnage
  • 2453
« Reply #8 on: October 29, 2007, 12:19:50 PM »
i could almost do a full oil change on mine
im 200lbs+ and mine has a full bodykit
but I still jacked up mine to be safe
i can do full oil changes on stock/lifted trackers without lifting it
just dive on in  8)
Ira
« Reply #9 on: October 29, 2007, 12:35:00 PM »
just dive on in  8)
How does jacking it up make it SAFER when your body goes under there!?
« Reply #10 on: October 29, 2007, 01:17:02 PM »
While you're at the tool store pick up a filter wrench too.
  • 416
  • Lil Suzys Dad
« Reply #11 on: October 29, 2007, 01:23:46 PM »
Jack stands!
Never get under a car without securing the vehicle with jack stands or something else which will keep it from falling on you.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #12 on: October 29, 2007, 01:31:01 PM »
just dive on in  8)
He meant safer for his body kit, not his body.
XL-7 front coils
Offline Carnage
  • 2453
« Reply #13 on: October 29, 2007, 01:47:02 PM »
just dive on in  8)
yeah, i tried ramps but the darn kit is too low and i scrape
and its safe(r) if you use jackstands
i typically use 2 jackstands and i leave the jack semi up
plus Ill chock the wheels and I might even throw a tire under the frame just to be safe
no need be scared  :)
  • 416
  • Lil Suzys Dad
« Reply #14 on: October 29, 2007, 02:10:59 PM »
Oh, my mistake, I wasn't sure, This is the same guy who wants to suck his engine oil out of the dipstick tube right?
