4.24 tranfer case gears install for sidekick
  • 3721 Views
Offline pdasilva
  • 71
  • Suzuki Rules...
« on: October 30, 2007, 07:35:41 AM »
Do i need to remove the entire gearbox to install these gears or can i just remove the tranfer box section?
Offline SnoFalls
  • 1358
Re: 4.24 tranfer case gears install for sidekick
« Reply #1 on: October 30, 2007, 09:57:49 AM »
with a manual, you pretty much need to drop tranny and tcase.
with an auto, you *may* be able to get to the top bolt (especially if you have a BL).
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: October 30, 2007, 12:55:36 PM »
I've never dropped the trans, only the t-case. The top bolt is a pain but it is not that bad.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #3 on: October 30, 2007, 01:00:08 PM »
I would agree with that, unless you don't have a 2" or 3" body lift.
I was able to remove the t-case off my tranny without too much dilemma, and i have a 2" body lift.  I don't think there would be enough room to get in to those top bolts if you didn't have it.
1993 4-door Sidekick
4.24:1 t-case
Offline cj
  • 1276
« Reply #4 on: October 30, 2007, 01:29:23 PM »
I've done it with and without a 2" bodylift on a manual. The bodylift makes it easier. Autos are even easier though.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #5 on: October 30, 2007, 05:02:08 PM »
Remove the cross over bar holding up the rear of the trans and let the trans hang.  This will give you a little extra room.  Remove the shifter (make sure its in neutral) and all the boots.  Now the tricky part. remove the 5 bolts for the shifter linkage.  Under that is the last bolt holding on the case.
When replacing the case leave that bolt out and the next time will be easyer.
32 MTR's Warn 8000i
Offline crikeymike
  • 713
« Reply #6 on: October 30, 2007, 08:57:43 PM »
Here are some photos to show you those bolts.
Click on them to make them HUGE.
« Last Edit: October 31, 2007, 10:16:14 PM by crikeymike »
4.24:1 t-case
Offline pdasilva
  • 71
  • Suzuki Rules...
« Reply #7 on: October 31, 2007, 04:45:06 AM »
I have the 2" body lift so that should make life easy.
How will the will the vehcile perform with these lower gears compared to stock?
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: October 31, 2007, 05:30:53 AM »
You will love them.  The only problem I've ever had was that they are too low for sand.  But I mostly drive in 2wd in sand anyway.
Good luck
32 MTR's Warn 8000i
