X-90 run mark-2 finished...
  • 9 Replies
  • 3571 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: November 04, 2007, 05:03:03 PM »
Just got back from the second X-90 pick up run and it was more or less a success. It took 4 states and around 450 miles round trip, but the 96 black 2wd X-90 is here at it's new home. I was kinda disappointed when I first saw it, it's pretty hammered, but it has great potential. I ended up paying $700 for it, so I got a deal, I think. It's got 114K miles on it, new tires, new clutch, newer starter and battery and runs like a top. It's pretty much rust free as well, which is always a good thing. ;)
Now for the bad: The rubber weather stripping is cracked, deformed, covered in rubberized sealant and some of it's missing. Several of the interior panels are broken or missing. The seat upholstery has several split seams and a couple holes. The exhaust leaks where the manifold meets the downpipe and the tailpipe tip is laying in the trunk. The hood and roof have serious paint issues, both fenders and quarter panels have dents, the trunk lid is dented and the wing is broken and laying in the trunk. When I went to turn up the radio, it shut off and wont come back on. The antenna is bent, the grille is broken and the front bumper skin doesn't appear to have much holding it on. The multi function switch on the steering collum(sp? LOL!) has some shorts; I have to hit the high beams to get the right turn signal to stop flashing, LOL! The door lock posts are missing and the windows have motor issues; the driver's window went down fine, but wouldn't go back up until I tore the panel apart. And the entire car seems to be listing to port badly.
I have a couple pics, I'll post them later. Originally I bought this to possibly get the parts to fix my red 4wd X-90, but the only parts on this one good enough for the red one is the headlights. Oh well... I have enough other pieces laying around to fix up the black one to be a real nice first car for my son who will be turning 16 in april, so it's all good. ;D
Offline SnoFalls
  • 1358
Re: X-90 run mark-2 finished...
« Reply #1 on: November 04, 2007, 05:41:39 PM »
even with those issues I wouolda snapped that sucker up for $700! Ya still got a good deal.
Find a "parts" tracker and ya can fix most of the issues. I bit of body work and probably some tube bumpers and it'll probably cleanup real good.
« Reply #2 on: November 04, 2007, 06:10:48 PM »
Funny thing is, That WAS a parts car X-90 :)
Dang, Your gonna need a Bigger Yard there Digger :D
Offline Digger
  • 1991
« Reply #3 on: November 04, 2007, 06:43:20 PM »
Yeah, but like I said the parts weren't good enough for my red X-90. That one's CHERRY, just ask Zig! LOL! So I guess Lil' Digger will have a zuk to drive when he gets his license...
« Reply #4 on: November 04, 2007, 09:26:44 PM »
Just giving ya Grief ;)
Will we see pics of your new project soon?
I'm looking for a new 2wd project myself.
Lucky me tho, I have a 4wd parts car;)
I so need to get another 4dr.
I'm thinking a lifted 2wd 4dr a/t for a D.D.
Offline Digger
  • 1991
« Reply #5 on: November 05, 2007, 02:05:59 PM »
Well, I just finished doing a little tinkering with it in the driveway. I fixed the belt squeal, they just needed adjusted tighter. I finally got the radio to come on, but not for long and the reception was horrible. I think the antenna or the cable is probably broken, and I'm not too sure about the radio itself. The previous owner had hacked into the radio harness and spliced in the wires for the Kenwood head unit, and they look like they were just twisted together and taped. Next trip to the junkyard and I will get the right radio harness and wire it in right so that a simple plug and play harness will plug right in. While tinkering with the radio, I discovered an A/C switch laying down behind the dash. Apparently the previous owner had put a HVAC control cover off of a car with no A/C and just laid the switch down behind the dash. I still haven't fixed the HVAC fan blower switch yet, but will once I grab the pieces. I think the one from the parts rig I scored off of Zig will fit.
I also managed to fix the lean to the left. See, when I drove to Tenn to pick up the parts Tracker from Zig, he had thrown all of his spare zuki parts in the back of it since he needed to clean up before moving. In the back of that tracker I found the stock coil springs and front arms from his X-90(which is now mine also, LOL!) from when he put the 2" lift on it. All I had to do to fix the black X-90's lean was replace the left front coil with one of the spare front coils I had gotten from Zig. Just to be sure, I stood all 3 front coils together(the one from the black one and the 2 from Zig) and selected the tallest of the three to put back on. The height difference was about 1/2" unloaded from the black coil to the tallest spare. Of course the black one had to fight with me a little bit; the top strut nut wouldn't budge, so I took the three strut mount nuts off instead and one of those fought me and then broke. So I had to press out the broken stud, while the mount was still attached to the strut, still attached to the car, and replace it with a bolt. Oh well. It's done now and it sits level again. I guess the spring had just sagged from age, maybe? There is no sign that this car had a fire or took any suspension or frame damage, and the previous owner was a lightweight girl, plus the driver's seat bolsters are still unbent and the bottom cushion is far from worn out, so I don't think any really heavy people were in it for any length of time. Before I replaced the spring, I thought maybe someone along the line had forgotten to replace the coil isolator, but it was still there and in good shape. The old coil looked fine, too. Not broken or bent, just a 1/2" shorter than the other 2 I had... Weird...
Anyway, I discovered a decently close junkyard with a couple X-90's and really good prices as well, so it shouldn't take much for me to have both X-90's fixed up again. Pics coming as soon as I get them off my camera and uploaded...
Offline Digger
  • 1991
« Reply #6 on: November 05, 2007, 02:20:30 PM »
Here's some pics:
Here she is as I was forking over the cash and getting ready to embark on my journey home:
She really doesn't look all the bad, but she's nowhere near as good shape as my baby. Check out the comparison view from before the stupid deer:
I think she's got great potential, the underside is in excellent shape, so at least there's that! LOL!
« Reply #7 on: November 06, 2007, 07:19:25 AM »
You had to thorw that last pic in there huh  :'(  Still looking good. Find a few new pannels, some paint and she will be back good as new.
Offline ToyYoda
  • 226
« Reply #8 on: November 06, 2007, 11:48:43 AM »
If you need any advice on building your X90 let me know as I have built 3 now & know what works & whats... >:(
Offline ToyYoda
  • 226
« Reply #9 on: November 06, 2007, 12:04:25 PM »
I like my 96 with the link/85 Yoda axles in it. Jeeps freak out every time.
