howling tranny
  • 2397 Views
Offline Eden1
  • 73
howling tranny
« on: November 04, 2007, 05:05:03 PM »
hey could someone tell me whats up here?its seams i have some howling in my transmission.mostly in 3rd and 5th gear.the rest seem to be fine?
thanks
Re: howling tranny
« Reply #1 on: November 04, 2007, 08:16:59 PM »
Sounds like some of the bearings are worn and starting to make noise.
« Last Edit: November 04, 2007, 08:27:34 PM by Skyhiranger »
Offline Eden1
  • 73
Re: howling tranny
« Reply #2 on: November 04, 2007, 09:02:13 PM »
does this meen rebuild time??if so ive never done it how hard is it
luvmysammy
Re: howling tranny
« Reply #3 on: November 04, 2007, 09:06:46 PM »
it's pretty easy, i have done quite a few. i suggest www.samuraiparts.com for the bearing kit. it is the cheapest i have come across and is a good kit. it u need advice on how to do it or where to start, pm me and i can send u a video i made when your ready to do it!
Re: howling tranny
« Reply #4 on: November 04, 2007, 09:25:54 PM »
It depends....are you talking samurai or trackick tranny?  In my experience, samurai trannys will run quite a while with noisy bearings, but trackick trannys will go downhill fast, once the bearings start howling.
It isn't bad to rebuild (I have only rebuilt a trackick one, but they are both basically the same procedure).  A bearing puller is needed, to pull some of the components.  And the best advice I can give.....pay very close attention to how the parts are assembled and in what orientation they come off of the shaft....some parts look like they can be put on either way, but if you look closely, there are some subtle differences in them.
Offline Eden1
  • 73
Re: howling tranny
« Reply #5 on: November 05, 2007, 05:41:49 AM »
sorry guys its a tracker ???.and its been howling for about 2 months and slowly getting worse.driving me nuts all along the way.lol
Offline locjaw
  • 2045
  • 22
Re: howling tranny
« Reply #6 on: November 05, 2007, 07:46:55 AM »
tracker tranny's are a dime a dozen. just swap in a used one and be done
jason
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: howling tranny
« Reply #7 on: November 05, 2007, 02:22:10 PM »
jason
and rebuild the one you have at your leisure. It's hard to know for sure how good a good used tranny is until you drop it in. I picked up 2 "good used trannys" I ended up rebuilding those 2 + the one I originally had. Now I have 2 good trannys left and sold 1. All for a sumurai (sorry) They aren't too bad to rebuild, just kind of messy. Shop press also helps. Hopefully your needle bearings are still good.
-Adam
