Sky idler arm?
  • 17 Replies
  • 5001 Views
Online ebewley
  • 6603
  • 69
Re: Sky idler arm?
« Reply #15 on: November 14, 2007, 02:21:36 PM »
Mine works great! I think there on backorder though ???
     Kevin
I emailed Sky and he said that the next batch is a few days out. So, if you're interested in an new idler arm, give them a call.
Re: Sky idler arm?
« Reply #16 on: November 15, 2007, 05:24:42 AM »
What's the procedure for changing the bushing?
Remove arm, knock out bushing, press in new bushing.  I cheated.  I lubed it and used the dead blow to whack it in.  No problem.
replace tie rod ends (inner and outter) if the are loose.  remove them to check, as mine felt fine while installed, but were really loose when I got them off.  I got all 4 rod ends from Rock Auto for under $100.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Sky idler arm?
« Reply #17 on: January 05, 2008, 07:44:52 AM »
So, digging this back up but where did you guys buy your Sky arms?  So far I've only found them from Sky and Low Range 4x4.  Do we get a discount from either of them?
