Need answer before tomorrow (11/14) T-case ?
  • 14 Replies
  • 3607 Views
Offline jerryp58
  • 449
« on: November 14, 2004, 10:35:31 AM »
For those of you who may have seen my transmission thread, you'll know I dropped the trans pan today.
Well, when I removed the drive shaft (DOH!  I just realized that I didn't need to remove it, I could have just detached it from the frickin' diff and moved it to the side  :-[ D|removethispart|@MN  :-[ )... Anyway, now that I dumped most/all of the t-case's gear oil on the garage floor, I can't get the frickin' fill plug off  >:(
It would be very bad to drive the vehicle with little to no oil in the t-case, right?  The gears (at least for the rear driveshaft) are always turning in there, right?
I think I'm gonna take it to the shop in the AM and get them to break that plug loose :-/
Jerry
Offline Mike71
  • 1449
Re: Need answer before tomorrow (11/14) T-case ?
« Reply #1 on: November 14, 2004, 10:50:45 AM »
what have u tried to get it losse? did u hit it with some penetrating lube
id hit it every hr for 6hrs with some PL
Offline Speedracer7c
  • 2210
« Reply #2 on: November 14, 2004, 11:01:50 AM »
did you try a little heat ?
Offline explosivo
  • 3157
« Reply #3 on: November 14, 2004, 11:16:23 AM »
There's a fill plug on auto trans? You could always just fill it through the dipstick tube, couldn't ya?
omghi2.us[/url]
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #4 on: November 14, 2004, 11:16:45 AM »
Take the shifter out and pour it through the top. ;)
  • 2210
« Reply #5 on: November 14, 2004, 11:31:54 AM »
He's talking about the t case
Offline explosivo
  • 3157
« Reply #6 on: November 14, 2004, 11:49:17 AM »
Just realized that.  :-X
« Last Edit: November 14, 2004, 11:49:46 AM by explosivo »
omghi2.us[/url]
Offline jerryp58
  • 449
« Reply #7 on: November 14, 2004, 01:07:32 PM »
I just bought some penetrating fluid today and I was thinking about spraying it down, but I was so disgusted that I just gave up.
Do ya'll just use the end of a 3/8" ratchet on those square holes?  I was using a couple of extensions and whacking the ratchet handle with a 2 lb hammer.  Didn't budge it >:(  I just don't understand how those things get so tight.
I may try it in the AM, but I'm likely just going to take it to the shop.  I don't want to end up rounding the plug out, then we're talking welding a nut head on it and more $$$.  I think I'll have them put a plug with a square bolt head on it.  They did that with the rear diff when I couldn't get that one off.  Maybe I'm getting weak in my old age :-/
Jerry
Offline jerryp58
  • 449
« Reply #8 on: November 14, 2004, 01:10:03 PM »
Ya know, I know it's supposed to work pretty well, but I've never tried that on anything.  I don't even own a torch (that what ya use, isn't it?).  I'd be too worried about setting the gobs of petroleum products down there on fire.
Jerry
Offline jerryp58
  • 449
« Reply #9 on: November 14, 2004, 01:11:29 PM »
Yea, that I can get to work.  Thank goodness the dipstick isn't bolted on  ;)
Jerry
« Reply #10 on: November 14, 2004, 01:12:04 PM »
Yes 3/8 ratchet, no extension and a
cheater bar (pipe) for more leverage,
if you are using a POS ratchet, be carefull
it doesn't break and you bust your knuckles
Offline jerryp58
  • 449
« Reply #11 on: November 14, 2004, 01:35:25 PM »
I used the extension to get past the t-case skid plate.
Somehow, I thought I had more than one 1/2" to 3/8" reducer, but I found out today that I gave my only reducer to a friend (lives too far away to bring it to me on short notice) so I couldn't use the larger 1/2" ratchet.  Actually I think I have a 3/8" that is about 1' long, but for some reason I was using a smaller (7" maybe) 3/8" Craftsman.  I don't particularly like its directional switch on it (it seems to switch too easily), but I figure with a lifetime guarantee I could whack it with the 2 lb  ;D
Jerry
Offline explosivo
  • 3157
« Reply #12 on: November 14, 2004, 01:35:28 PM »
As an extension to this post: watch out for the ratchets that have rounded edges. I've had the best luck with the ones with sharp edges... otherwise you're liable to round out the hole.
omghi2.us[/url]
Offline Mike71
  • 1449
« Reply #13 on: November 14, 2004, 01:40:09 PM »
u can put more force on it with a pipe over the end of the ratchet rather then hitting it with a hammer
the hammer puts force on it but not like a 2' piece of pipe =)
Offline Bfunk
  • 406
« Reply #14 on: November 14, 2004, 04:13:27 PM »
when I first got my rig and did all the fluid changes I had to use my 3/8 impact on it.  Ifyou have one use it, if you don't locate one and use theirs ;)
Brian
