Tracker Diff Questions
  • 3006 Views
Offline explosivo
  • 3157
« on: November 13, 2004, 10:02:17 AM »
Can you bolt the third member from the rear axle of a Tracker into the front differential housing?
omghi2.us[/url]
Re: Tracker Diff Questions
« Reply #1 on: November 13, 2004, 11:52:04 AM »
No, ring gear is too big
but you can bolt the rear
3rd member of a Sammy to the
front of a Track/Kick
Or was that just the carrier ???
Offline explosivo
  • 3157
« Reply #2 on: November 13, 2004, 02:26:50 PM »
Then what about using the carrier from the front diff in the rear third in the front diff housing?
omghi2.us[/url]
« Reply #3 on: November 13, 2004, 06:49:38 PM »
Hmm...... never tried that, it might work
if the rear 3rd member fits the bolt pattern
of the front housing
Let us know if it fits :)
« Reply #4 on: November 14, 2004, 04:56:40 AM »
I'm 99.9% certain that the answer is no. I will double check tomorrow if I get home before it gets dark. The sammi 3rd member fits but the R&Ps are different ratios.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: November 14, 2004, 05:00:58 AM »
The rear diff of a sidekick is SO much bigger than the front. Even the diameter of the third member itself, where it bolts up.
It won't work.
Heather Galvin
Offline explosivo
  • 3157
« Reply #6 on: November 14, 2004, 07:14:17 AM »
Darn. I was hoping that I'd be able to get a steel 3rd without paying a buttload of money :(
omghi2.us[/url]
Offline SnoFalls
  • 1358
« Reply #7 on: November 14, 2004, 10:19:09 AM »
I hear ya ... it's insane what they run
