Kick timing belt broke: How to time camshaft pulley?
  • 2596 Views
Offline RifleRide
  • 29
  • Mentor a Child!
« on: November 14, 2007, 05:08:33 PM »
Well it happened today, timing belt broke on 1.6 Sidekick.  Got to apart, got crankshaft pulley on timing mark, number 1 is top dead center but camshaft pulley is not on number 1 firing position when the pulley is at timing mark! In my book if talks about if all pullies are aligned, rotor button will be at Number 4 on compression.  Is this right or what do I need to do..  I searched the archives and could not find an answer.   Help me!!!
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Kick timing belt broke: How to time camshaft pulley?
« Reply #1 on: November 14, 2007, 09:00:08 PM »
Try this... http://www.autozone.com/az/cds/en_us/0900823d/80/1d/f3/f8/0900823d801df3f8/repairInfoPages.htm
If your truck is a 16V just change the vehicle at the top of the page. If it is a 16V you probably have bent valves.
Student of Now Master of Then
Offline ChileKick
  • 75
  • DIYer Man !
    • Nacion 4x4
« Reply #2 on: November 15, 2007, 02:51:48 PM »
"number 1 is top dead center but camshaft pulley is not on number 1 firing position when the pulley is at timing mark! "
I bet it's on 4 firing position. Sidekicks acording to manual are supossed to be timed on cylinder number 4 , thats when both timming marks are aligned , the cranshaft pulley to the small triangular marking on the oil pump , and the camshaft pulley on the small dent marked on the thin metal protector where the timing cover bolts to.
If you turn your timing marks facing each other you will get top dead center in 1 and 1 firing position on your distributor , just keep the crankshaft at position an rotate 180 degrees the camshaft pulley so the marking in it faces directly the marking in the crankshaft.
Cheers
Custom 5" suspension lift,custom 2"body lift, custom transmision lift,custom intake porting and custom exhaust.
3" wider A-arms custom made front coils.Power inverter , dual batteries , 8000lb winch , VHF , AM , LSB , On board Notebook-GPS on 15" Screen :-)
 265/70 - 15 tires on 8 rims. Custom Man
