what years will fit
  • 2303 Views
Offline 94track
  • 212
what years will fit
« on: November 12, 2004, 08:43:24 AM »
i need to get a front diff. assembly and axles for my track. Does anyone know what years they are the same for, i am also assuming that a kick assem. will work also.  I have a 94 track 16v.  Also, anyone from nepa know of any junkyards that would have this, I really don't want to waste a trip down to harrys if i don't have to.
Re: what years will fit
« Reply #1 on: November 12, 2004, 11:06:18 AM »
If you get a diff and axles from the same
vehicle it really doesn't matter, all the diffs
will fit and work thru 97 or 98 at least.
What might make a difference is if you want
the strongest available, then you want the
26 spline axles and diff section
Good Luck
« Last Edit: November 12, 2004, 11:06:49 AM by wildgoody »
Offline Bfunk
  • 406
« Reply #2 on: November 13, 2004, 01:21:08 AM »
If only you weren't so far away.  I  have all that stuff sitting in pile on my garage floor.
Brian
Offline 94track
  • 212
« Reply #3 on: November 13, 2004, 02:16:14 AM »
thanks anyway brian, let me tell you 31's and some wheel hop can do some damage.
Offline 94track
  • 212
« Reply #4 on: November 13, 2004, 07:32:50 AM »
Why i need a new diff....
Offline blacknight
  • 987
    • Gonzookin
« Reply #5 on: November 13, 2004, 09:34:30 AM »
Get a steel one from a GV 99+ (with man. trans.)  its all steel plus the mount on the 3rd is beeffer too.
George
Offline 94track
  • 212
« Reply #6 on: November 13, 2004, 09:47:17 AM »
are axles for the track going to be the right lengths with a diff from a gv?  what i mean is, is the GV diff going to be a direct replacement for my truck?  It would be great to have a steel diff., so this doesn't happen again.
Offline explosivo
  • 3157
« Reply #7 on: November 13, 2004, 09:59:47 AM »
You can use the steel housing and 3rd with your tracker carrier/gears/axles (from what I understand.... I could be wrong), since the steel housing comes in auto GV's, which have a different gear ratio than the manual version.
omghi2.us[/url]
