zuktoy small body mod
  • 1821 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: November 15, 2007, 08:10:51 PM »
ok im slowly working to the axle swap just a small up date hear . my body mounts where getting munched by the rock so i decided to move them up to the level of the body. it has a 3 inch lift so i cut them off the frame and welded them to a plate and then welded the plate to the frame. well hears pix. im going to be starting on the link supports this weekend. for those that haven't been following and don't know what the zuktoy is search for zuketoy you will get the whole thing.
Re: zuktoy small body mod
« Reply #1 on: November 15, 2007, 09:38:09 PM »
That looks alot better than what you had, the only thing I would do diffrent is to make the plates welded to the frame more of a diamond shape, I never liked welding streight right angle plates on a frame, I have to do the same thing soon on my sammie for the shock mounts, been putting it off!
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: November 16, 2007, 03:39:28 PM »
Yes what fuel said. I have ripped off my larger/higher mounts also. I now have a crossbar to tie the two together. It works better.
    Kevin
