88 Zuki Crappy Carb?
  • 20 Replies
  • 4258 Views
Offline Raven
  • 15
  • Lost in the 100 Acre Woods
    • Raven Off-Road
« on: November 08, 2004, 04:44:32 AM »
Ok - throttle pedal - First 1/2 no problem - accelerates as much as a 1.3l on 32's can. Second 1/2 - nothing. Not there - just makes the carb load up and choke. Starts sputtering and coughing. Is THE secondary not opening? A vaccum line?
This tiny thing is confusing me - I've only ever worked on my 304 with a 4 bbl and I've never had a 'too much fuel' problem.
Reality is always better than fantasy ~ If you think I'm wrong ~ I'll prove it...
Offline motoxjesse
  • 21
  • I wish I had an LJ
Re: 88 Zuki Crappy Carb?
« Reply #1 on: November 08, 2004, 06:43:58 AM »
ok dude you need to get the ventury tube for that carb to eliminate any flat spots in your acceleration, talk to a suzuki dealer they'll know
« Last Edit: November 08, 2004, 06:44:18 AM by motoxjesse »
Offline Raven
  • 15
    • Raven Off-Road
« Reply #2 on: November 08, 2004, 06:47:12 AM »
Yeah - chick walks in and says
*ahhmmmm* clearing throat 'Could someone please give me a ventury tube' *fluttering eyelashes* I'm sure I'll be gettign afew offers - but the wrong tubes ;)
Thanks - I'll call over there and see what's up ;D
  • 6597
  • 68
« Reply #3 on: November 08, 2004, 06:52:14 AM »
Well if you're not comfortable with that. Give Hawk Strictly Suzuki a call 888 SAMURAI they can help you over the phone. However, it may not be a broken part. Check all of your vacuum lines to make sure they are connected in the right place and in good shape. ALso, when is the last time you changed the fuel filter? Maybe bad gas?
Good luck,  -Eric
Offline Raven
  • 15
    • Raven Off-Road
« Reply #4 on: November 08, 2004, 06:57:33 AM »
I'm comfortable with it - I was only playing - sorry - way to flirtatious natural for a new board.
I don't have a vaccum diagram - so I have no idea if they are in the right places.
I changed the fuel filter 2 weeks ago.
  • 6597
  • 68
« Reply #5 on: November 08, 2004, 07:01:11 AM »
DId the problems start then?
Offline Raven
  • 15
    • Raven Off-Road
« Reply #6 on: November 08, 2004, 07:05:53 AM »
Nope - been there since I got it two months ago - really noticed a change when upgraded from stock tires to 32's.
It has been getting a little worse as time goes by.
I changed it - hoping it would make a difference - it did get a little better - but not enough to write home about.
Changed the spark plugs at the same time - no change there. (they were black though ;) )
Offline azrocktrash
  • 121
« Reply #7 on: November 08, 2004, 08:01:05 AM »
Good luck,  -Eric
i'll second that.ask for william,he'll be able to anwser any questons you have.vacum and such.
    AZ
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
« Reply #8 on: November 08, 2004, 11:02:51 AM »
Hi there raven.....nice to see you here also. as for zook carb problems youre in the right place. can you take a pic of what the drivers side of the carb looks like? from there most of us could help you with vaccum line routing.
ok heres some pics
stock setup
modifyed setup...(no emissions)
« Last Edit: November 08, 2004, 11:56:49 AM by bigzook »
Offline Mel Taylor
  • 21
« Reply #9 on: November 08, 2004, 11:40:07 AM »
Raven,
I just sent you an e-mail with a vacuum hose diagram.
Mel Taylor
When you hold the shift key down and type 4X4 it comes out $X$. Could anything be more appropriate?
Offline Raven
  • 15
    • Raven Off-Road
« Reply #10 on: November 08, 2004, 02:43:23 PM »
thanks guys - I'll take pics tomorrow during the day (better light ;) )
And thanks mel for the diagram and  ElBurro - honey - i'm everywhere ;D I just lurk until I have questions that aren't answered with the search feature :-*
« Last Edit: November 08, 2004, 02:51:56 PM by raven »
  • 6597
  • 68
« Reply #11 on: November 09, 2004, 01:04:59 AM »
ok heres some pics
stock setup
Um, those pictures do not depict stock vacuum line rounting.. FYI :)
« Reply #12 on: November 09, 2004, 01:09:31 AM »
I thought the top ones were....hmmm been a long time since I have seen stock. Sorry about that raven.
  • 6597
  • 68
« Reply #13 on: November 09, 2004, 01:13:47 AM »
The first give away is that the flow restrictor/check valve for the vacuum secondaries is gone and bypassed. You know, the 'hop up' mod... :)
Offline Raven
  • 15
    • Raven Off-Road
« Reply #14 on: November 09, 2004, 01:23:28 AM »
Well - I don't have to pass DEQ if that matters ;D
