Boondox Motorsports Lifts
  • 21 Replies
  • 5684 Views
96kickjx
« on: November 23, 2007, 07:42:09 PM »
I was looking around and doing some googling researching suspension lifts for the sidekick to go along with my 3" bodylift from Calmini and I came across Boondox Motorsports. They have some pretty decent looking lift systems, but I wanted to know if there's anyone on here that has tried any of their lift systems, and how have they worked out. What I'm mainly looking at is their strut extenders, and the procomp longer travel shocks. I want to buy a set of Jeff1997's spacers to go along with it. So if anyone has any info please let me know.
O
Offline museboy07
  • 641
Re: Boondox Motorsports Lifts
« Reply #1 on: November 23, 2007, 09:19:14 PM »
They use a pretty good setup.  Its a full coil lift with NO spacers.  I have a the strut extenders and the procomp long travels from them.  Just good luck getting a hold of him.
1994 Tracker, 2in Ironman springs w/ 1in spacers on top, soon to have custom diff drop brackets, 31x10.5-15 All Tarrains, Pro Comp long travel shocks, KYB performance struts, strut mount flip w/2in extensions, 3in rear a-arm spacer, ...DD
96kickjx
« Reply #2 on: November 24, 2007, 06:51:59 AM »
Okay, so lets say I got their 1.5" Suspension lift including the 1.5" spacers, 2" strut extenders, 2" rear shocks, which would give me 4.5" of lift, would I be able to fit 31's, with minor or no trimming?
Offline museboy07
  • 641
« Reply #3 on: November 24, 2007, 07:06:52 AM »
there 1.5in lift uses coil spacers.  i was talking about all coil on there 3in lift.  but i wouldn't use 1.5in spacers with there 3 inch lift. i'd do the 3in sus. lift and a 2in body lift to clear 31s
96kickjx
« Reply #4 on: November 24, 2007, 07:14:39 AM »
Yeah I know, 3" is a little out of my price range though. I already have a 3" body lift from calmini. Boondox has the 1.5" susp. lift for a more affordable price.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #5 on: November 24, 2007, 07:22:55 AM »
I run boondox 4 door 3 inch lift springs in my 2 door tracker.  Very nice setup, but I am not sure if you can still get ahold of boondox.  I know most of there stuff been out of stock for awhile, although I havent checked there website lately.
Offline museboy07
  • 641
« Reply #6 on: November 24, 2007, 07:25:16 AM »
if you already have the calmini 3in body lift then just get a set of coil spacers from jeff1997.  Use 1.5in in the front and 2in in the rear for a full 2in extra lift.  Then just flip your strut mounts and get some $20 dollar ford crown vic shocks.  You'd clear 31s easy.
96kickjx
« Reply #7 on: November 24, 2007, 07:29:31 AM »
Yeah that's the thing I don't understand. I'm new to the lifting game, how does that strut mount flip work, don't you have to do something to the holes for it and get bigger bolts? I think I read something about that. Before I even came across Boondox, I was considering Jeff's Spacers.
Offline john1974
  • 617
    • Zuknation
« Reply #8 on: November 24, 2007, 07:47:57 AM »
strut mount flip just needs the stut mount studs knocked out and replace the bolts.  very easy to do.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #9 on: November 24, 2007, 07:55:36 AM »
Yes that is right; what you flip is the strut cap. That is the plate that has 3 studs holding it on to the strut tower, and the top of the strut goes through the middle. Put a proper sized 12 pt socket on the back side and use a hammer or vice to knock out the stud. Drill out the hole to the next larger size, be sure the bolts you use will still go through the holes in the strut tower. Now when you put the assembly back together put the strut cap in up-side-down. you have just added about 2 inches to the down travel of the front suspension.
Student of Now Master of Then
96kickjx
« Reply #10 on: November 24, 2007, 08:06:53 AM »
Okay thanks, now do the crown vic shocks bolt right up without any modifications?
Offline john1974
  • 617
    • Zuknation
« Reply #11 on: November 24, 2007, 08:09:11 AM »
Depends on the total size of your lift.  I am using ford f150 shocks for now until I can afford some softer shocks there way to stiff.
  • 416
  • Lil Suzys Dad
« Reply #12 on: November 24, 2007, 08:15:15 AM »
Can the crown vic/F150 shocks be used on a truck without the Hagen over-rotation on it?
Offline john1974
  • 617
    • Zuknation
« Reply #13 on: November 24, 2007, 08:20:15 AM »
Ya mine are in the stock position, although its a tight fit.
96kickjx
« Reply #14 on: November 24, 2007, 08:21:55 AM »
Well I was gonna get Jeff1997's Spacers, which will be 2" of lift so will the vic shocks work without modifications with that lift?
