OME GV springs on 2dr Trackick..
  • 32 Replies
  • 7209 Views
Offline museboy07
  • 641
« on: November 25, 2007, 08:27:30 AM »
Anyone experience with this??  I was thinkin the medium duty GV springs on my 2dr tracker.  I bet it would still ride decent.  I'm kinda wondering what amount of lift it would yield.  I'm looking to get at least 2.5in.  If this isn't a great idea then someone direct me to some readily available springs that will yield a minimum of 2.5in that i could look into.  Thanks!
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: OME GV springs on 2dr Trackick..
« Reply #1 on: November 25, 2007, 08:06:19 PM »
OME 962 is what you are looking for
Offline museboy07
  • 641
« Reply #2 on: November 26, 2007, 09:41:04 AM »
OME 962 are the GV heavy duty coils...wouldn't that ride kinda harsh??  How mush lift would they yield??
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #3 on: November 26, 2007, 11:24:20 AM »
I don't have first hand knowledge of this spring in your application but I would suggest that if Mike says it will work then it will work.
Student of Now Master of Then
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: November 26, 2007, 02:33:01 PM »
I cant remember the exact amount of lift but I want to say 3 inches. They rode awsome in my rig. Another guy in our club runs them in is rig too and it is a lightweight rig.
Mike
Offline museboy07
  • 641
« Reply #5 on: November 26, 2007, 06:58:48 PM »
Nice...3in is what im looking for...and $66 a coil...you can't beat it
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #6 on: November 26, 2007, 08:32:21 PM »
Make sure you post results to this thread if and when you get them so others can see how it works.
I'd be guessing 2.5-3.0" of lift...  Check the struts though once they're in, because you don't want to be riding around with them at full extension.  You'll booger them up pretty quick.
1993 4-door Sidekick
4.24:1 t-case
Offline museboy07
  • 641
« Reply #7 on: November 27, 2007, 03:49:50 AM »
OME 962 are gv heavy duty for the front...they only list one rear selection for the GV which is OME 961.  Is that what i get??
..two OME 962 for the front and 2 OME 961 for the rear??
  • 416
  • Lil Suzys Dad
« Reply #8 on: November 27, 2007, 08:46:20 AM »
I saw in another thread somewhere that the GV rear springs are a different diameter. What you want are the heavy duty 4 door springs.
Offline museboy07
  • 641
« Reply #9 on: November 27, 2007, 09:34:18 AM »
So which ones...GV heavy duty fronts and GV rears or 4 door heavy duty for all four???
  • 416
  • Lil Suzys Dad
« Reply #10 on: November 27, 2007, 09:40:19 AM »
4 door heavy duty in the rear GV heavy duty in the front.
Offline crikeymike
  • 713
« Reply #11 on: November 27, 2007, 10:32:13 AM »
OME955's in the back (4-door heavy load rears), and OME962 (GV heavy fronts) or OME959 (4-door heavy fronts).  Without using coil spacers, the 962 will yield more lift, just don't know how much.
Switch around to ordering it by part numbers, instead of description, because you'll confuse the hell out of whoever it is you order from.
4.24:1 t-case
Offline museboy07
  • 641
« Reply #12 on: November 27, 2007, 11:14:35 AM »
Ok so what i should get is GV HD fronts and 4 door HV rears??  And this will yield 3in of lift??  Sorry for the questions i just don't want to order the wrongs things.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #13 on: November 27, 2007, 11:19:51 AM »
The OME 956 springs for the front of the XL-7 will yield a bit more lift than the 962 springs and they have a slightly softer rate at 500 instead of 540.
The 955 springs will need spacers added to give 3" of lift.
Offline bzzr2
  • 1011
« Reply #14 on: November 27, 2007, 11:32:06 AM »
Try a rear XL7 lift spring, I use stock xl7 rear springs on my 2dr, not sure how much lift that produced from stock height but more than an inch, I have this combined with a heep spacer. but maybe the OME's will do the trick.  Just a thought..
09 taco reg cab short box 4x4
