Headlight issue (96 tracker)
  • 1821 Views
Riddick
« on: November 28, 2007, 12:29:13 PM »
So today I decide to buy some new headlights for my 1996 tracker I just purchased last night.
I noticed today after installing the headlights that when turned on, one headlight is on low beam and the other high beam but when I hit the high beams, they one on low goes to high and the one high goes to low. they basically switch.
Can anyone explain to me what's up? This rig was used as vehicle that was towed behind a RV, could they have spliced the wiring or is it something else?
Offline gravity_storm
  • 108
  • The wino and I know
Re: Headlight issue (96 tracker)
« Reply #1 on: November 28, 2007, 01:11:15 PM »
When I got my 96 kick it had the same thing going on. I pulled the bulb that was 'wrong' and rotated it and the problem was solved. On my other vehicles the bulb was indexed where it could only be installed in one position but this does not seem to be the case for the Track/Kick.
gravity storm
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: November 28, 2007, 09:12:51 PM »
gravity storm
Good idea, something you should check.
Also, you could swap the bulbs from side to side to make sure that one of the bulbs wasn't made incorrectly.  That could happen.
You never know with RV setups.  The wiring could have been used for something, but it's not very likely as they only need the brakes and turn signals hooked up for towing.
1993 4-door Sidekick
4.24:1 t-case
Riddick
« Reply #3 on: November 28, 2007, 10:48:03 PM »
thanks for the tips. Yeah all I had to do was rotate the bulb and now we are golden...
Those new sylvania xtravision are really bright
