Adjustable rear suspension
  • 2504 Views
Offline skandy32
  • 93
  • Zukiworld Rocks!
    • Andy Colver Photography
« on: November 28, 2007, 05:17:53 PM »
I'm toying with the idea of finding some sort of adjustable rear springs / suspension for my zuk.
I have a swb, i have stock springs, with coil spacers and this is all fine with 2 people riding in the front seats. The second i have 4 people seated, i've got a super a saggy and slightly too soft rear end, with low beam lights blinding traffic on the roads. So i need harder springs in the rear right? But i love the way it rides with just 2 people, it's just right and comfy.
Is there any adjustable spring - type thing on the market? Maybe an airbag spring idea? I've been searching the forum, but not found anything connected to this (yet).
Any thoughts guys? anyone else know my problem? I could just fit lwb rear springs and be done with it, but the word 'adjustable' is attractive :) hehe
Andy
UK Vitara - 2" spring/shock spacers, 3" calmini body lift, 32x11.5x15" BFG MTs, rear half calmini exhaust/no cat, full Alpine ICE
http://www.andycolver.co.uk
Re: Adjustable rear suspension
« Reply #1 on: November 28, 2007, 07:18:04 PM »
Any airbag kit should be able to work.  Just find a really small one.  :)
One of the Air Lift kits from a Toyota mini pickup could probably be modified rather easily.
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #2 on: November 28, 2007, 10:46:11 PM »
I've seen some adjustable coil spacers, they were aluminum rings with steps to change three settings. But the biggest problem is needing to completely unload the springs to change the hight. Not something you want to do every time you pick some buddies. Go with air bags if it's feasible.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline skandy32
  • 93
  • Zukiworld Rocks!
« Reply #3 on: November 29, 2007, 02:39:52 AM »
anyone have a link to one of these airbag kits?
« Reply #4 on: November 29, 2007, 03:41:16 AM »
JC whitney sells an airbag kit for the rear of the Trackicks, Made by AirLift. I have it installed in mine for use when I pull my Camper. I think the whole kit was around $70, and It works very well. You will have to make a spacer for the bags that equals the amount of spacer lift, or better yet, DO NOT cut the bump stops down as described in the instructions, Then it should fit the bag fine.
kingzoo
« Reply #5 on: November 29, 2007, 09:10:10 AM »
   I used the same bags with a shitty on board compresor and it worked well enough to compensate for the added weight.The 4 door I bought in May has no problem with the extra weight.
Offline skandy32
  • 93
  • Zukiworld Rocks!
« Reply #6 on: November 29, 2007, 02:57:25 PM »
Air bags...
http://www.jcwhitney.com/autoparts/Product/tf-VehicleBrowse/s-10101/Pr-p_Product.CATENTRY_ID:2005927/p-2005927/N-111+1994+200729252+600003409/c-10101
Air compressor...
http://www.jcwhitney.com/autoparts/ProductBrowse/showCustom-0/makeName-Suzuki/makeId-84/modelName-/modelId-/year-/refId-20004540/Pr-p_Product.CATENTRY_ID:2005935/c-10101/p-2005935/N-111+600003409+20004540/tf-Browse/s-10101/mediaCode-ZX
Thats awesome, and incredibly cheap to my suprise! I have a ew more questions no though, im quickly becoming interested in this, ha ha! I shouldn't have asked in the first place!
Is there a set available for the front? If i could stiffen up my whole ride, road-driving altogether would be better!
Would they still work with longer springs?
Is there any simular thing that would adjust my lift too?
Cheers, Andy :)
« Reply #7 on: November 29, 2007, 04:05:45 PM »
None available for the front that I know of, and I looked. They will not give you any noticeable lift, maybe 1/2 ", but they will keep the back end from sagging. I just fill mine with any air hose, a compressor really isn't necessary, unless you already have one.
