Saggy front springs.
  • 8 Replies
  • 2485 Views
Offline Cwkick
  • 888
« on: June 15, 2005, 02:22:19 AM »
The front of my 97 Tracker is a little saggy.  I think it is down about an inch.  This has been exagerated by the Calmini 2" lift.  I am looking to lift the front about an inch to level everything out.
Please correct me if I am wrong, but it seems spring spacers are about a 2 to 1 ratio.  That is a one inch block give you about two inches of lift.  If I use a half inch block, that should give me about an inch of lift, correct?
Cwkick
Offline 92Sidekick4x4
  • 1456
Re: Saggy front springs.
« Reply #1 on: June 15, 2005, 03:16:00 AM »
i *think* yer right, id probly go with rocky roads spacers
Offline SnoFalls
  • 1358
« Reply #2 on: June 15, 2005, 04:56:11 AM »
Cwkick
I think it's more around 1.5:1 ... a 1.5 spacers seems to yield about 2" or so of lift.
  • 6598
  • 68
« Reply #3 on: June 15, 2005, 05:34:29 AM »
Cwkick
From the ZUKIWORLD Gear Guide Section:
http://www.zukiworld.com/month_050103/feature_wheelers_spacers.htm
HTH, Eric
Offline jagular7
  • 1026
  • Jagular7
« Reply #4 on: June 15, 2005, 06:46:24 AM »
Best way to configure it to take it apart only once, is to use a jack to lift the front up. Measure at the coil the coil static height. Lift to height necessary to balance front to back, remeasure in the exact same location. The difference is the height required.
Lenexa, KS
Offline Cwkick
  • 888
« Reply #5 on: June 15, 2005, 07:09:13 AM »
That's a darn good idea!
Cwkick
« Reply #6 on: June 15, 2005, 07:52:20 AM »
Plastic surgery can fix her sagging parts right up, but it will cost ya ;D
Offline Cwkick
  • 888
« Reply #7 on: June 15, 2005, 08:43:15 AM »
And the perky front end IS worth it!!   ;D
Cwkick
Offline SnoFalls
  • 1358
« Reply #8 on: June 15, 2005, 09:20:32 AM »
no doubt!
oh ... you're talkin bout the truck ...
