KIC THAT SPUTTERS??????
  • 3150 Views
Offline zukinator-z
  • 76
« on: December 07, 2007, 08:14:36 AM »
I HAVE A KICKER THAT ONLY WHEN WARM AND UNDER FULL THROTTLE MISSES AND IT DOESN"T DO IT ALL THE TIME. I have put a new comp. in new fuel pump and filter and coil .any other suggestions??????? ??? ??? ??? I"m losing my mind over this.It seams that when my wife is on the throttle going up a hill or coming out of a mud hole is when it happens most{under load}.Could it be a fuel preassure problem?????
94  Zuki sidekick 2 '' spacer. 3'' body 31'' Bfg MTs,miller lckr rear . Wifes ride, 93 Zuki sidekick,30'' Super Swampers digger spacers,Miller locker rear.88 Zuki,POS,full cage,31 "BFG MT's,Miller rear, lock-rite front,and 5:13 gears.
Offline SnoFalls
  • 1358
Re: KIC THAT SPUTTERS??????
« Reply #1 on: December 07, 2007, 12:06:09 PM »
Could just be a missfiring plug ... I had that exact symptom (and I think CrikeyMike did too) ...
In both cases it was our #3 plug wire either broken or not properly connecting to the plug.
Note: in my case it would idle just fine, and a timing light would show the plug wire firing ...
I also would agree that low fuel pressure can result in a similar symptom.
kingzoo
« Reply #2 on: December 07, 2007, 12:07:54 PM »
   I agree,it is most likely related to a plug or plug wire.You might want to put a fuel pressure gauge on it just to be sure.
Offline justzukies
  • 88
« Reply #3 on: December 11, 2007, 12:40:34 AM »
Only missing after warming up is a classic coil problem, the coil expands when warm and can then seperate, but close agian when cold.  said you changed coil but may be bad too.  not likely but can only try different ones to eliminate as problem.  my 94 kick would miss bad one day and be fine the next.  but it missed cold or hot.  ended up being a short in the wireing harness.  It drove me mad and I drove it mad.
94 kick 1.6 16V AT 4dr  Calmini 3" lift
Offline zukinator-z
  • 76
« Reply #4 on: December 11, 2007, 05:54:30 AM »
Here is my update with no sollution .Changed plugs and plug wires dist cap and rotor .I fired it up drove around the field till it got warm went down to a steep hill climbed the hill no problems ,got out on the road hammered down started missing again!!!!!!!!!! AHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #5 on: December 11, 2007, 07:34:28 PM »
I had a Jeep YJ that would sputter whenever I started cruising down the road but was fine under acceleration.  Ends up it was the Oxygen sensor.
Offline SnoFalls
  • 1358
« Reply #6 on: December 12, 2007, 07:10:43 AM »
BTW, I had a rig once that had the return line to the fuel tank plugged and had similar symptoms. (that had me tearing hair out also)
Offline zukinator-z
  • 76
« Reply #7 on: December 17, 2007, 05:47:28 AM »
That is definitly worth a try.Thanks for the info!!!!!! ;D ;D ;D.
