two piece hard top seals/rubbers?
  • 2122 Views
bruce5385
« on: December 10, 2007, 02:47:48 PM »
I have a two piece hard top and dont know where to get new seals /rubbers for it.  also one of  the latches that hold the front piece down is broken?  anyone have an idea where i can find these parts?  thanks bruce
« Last Edit: December 10, 2007, 07:45:57 PM by bruce5385 »
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: two piece hard top seals/rubbers?
« Reply #1 on: December 10, 2007, 10:52:32 PM »
People have used the peel and stick foam weather stripping to replace the rubber.
Latches? The stock latches above the visors or the aftermarket top latches? If the latter you need to find the manufacturer or get lucky at the local hardware store.
Student of Now Master of Then
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #2 on: December 11, 2007, 01:19:46 PM »
My two piece has the molding around the outside but when I bought the samurai it was missing a section of the front side. I part out the sidekick and trackers so I got to looking at the door molding and on the 96 tracker the front door molding has the rubber seal on it also which is just like the molding around the hard top. So if you can track one down and use those. Not sure about the inside of the seals but this one also has the peal and stick weather stripping.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
Offline Terry329
  • 59
« Reply #3 on: December 14, 2007, 10:26:54 PM »
replacement seal material and latches can be purchased from rally tops.  dont remember how much the seals were but the latches were around 15 bucks each.
Cuthulu
« Reply #4 on: December 15, 2007, 07:33:15 AM »
Try a local RV/camper store.  Most of them deal in camper shells and truck shells.  I had to do some restoration work on mine when I get it and I was able to get what I needed there.  Also I pull my top off a few times a year so that I can armor all the seals.  I live in Northern CA right now so no snow but alot of rain.  Mine has never leaked once I fixed the seals.
