Uh Oh gas problem?
  • 10 Replies
  • 2987 Views
Shizamaaur
Uh Oh gas problem?
« on: December 10, 2007, 06:08:32 PM »
Hi all, I'm trying to figure this out. I am getting about 14 MPG with 29 inch tires, and stock 1.3 L in Sammy. I have no freaking idea why this is making me mad, are there points on the 87 sammy where there are frequent gas leaks? I've looked and cant find anything. I KNOW I shouldn't be getting that bad  of MPG.... THANKS ALL!
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Uh Oh gas problem?
« Reply #1 on: December 10, 2007, 09:43:31 PM »
I wouldn't worry about a gas leak unless you can smell gas around the vehicle. If there are no obvious odors of gas, you are probably not dealing with a leak. Is this a Stick shift or Auto trans? I would suspect maybe binding in the driveline or clogged air filter/intake or exhaust...
Shizamaaur
« Reply #2 on: December 12, 2007, 06:15:53 PM »
5 speed. That just seems like horrible gas mileage to me...
phloop
« Reply #3 on: December 12, 2007, 06:33:45 PM »
Digger, Sammy's do not have auto's.
As far as MPG goes, my Sammy gets around that I guess. :laugh: At the time I was checking the mpg, it had a Weber, header w/2" exhaust, 4.16 gears in the TC and 32" Swampers. The speedo is off cause of the gearing and tires and I have never bothered to do the math to figure out the correction factor.
And also make sure it is in good tune. That would be the first place too look. And if you are comparing it to a stock Sammy it will be down because of the tires to start with.
Offline Digger
  • 1991
« Reply #4 on: December 12, 2007, 07:20:48 PM »
DOH! My bad... I wasn't fully awake I guess... LOL! :P
Offline Gary_Hill
  • 288
« Reply #5 on: December 12, 2007, 07:50:50 PM »
In Diggers defense... http://www.suzukiconversion.com/suzuki_jono.htm Don't know if his reputation for dependability has improved...was kinda poor a while back. Shure builds pretty trucks though, if you likr pretty...
Shizamaaur
« Reply #6 on: December 12, 2007, 09:37:15 PM »
Wow, I just dont understand how it could be that terrible, I have done a full tune up too.. lemme get the specs of my tires... 235-75-15 m+s        (other than that, it's all stock)
« Reply #7 on: December 12, 2007, 10:55:49 PM »
The carbs on these are a step below FI. They have a lot of electronics / vacuume lines to control the Air/ Fuel mixture. If something in that system is broken, it could be making the truck run WAY too rich...
« Reply #8 on: December 13, 2007, 04:35:39 AM »
What colour are the spark plugs running?
Shizamaaur
« Reply #9 on: December 13, 2007, 03:08:44 PM »
Um I'll check.. I'm a noob, does that just mean.... what color are the spark plugs where is sparks?
Offline SnoFalls
  • 1358
« Reply #10 on: December 13, 2007, 04:26:35 PM »
yes, get a pic ...
