Spring spacers .
  • 2657 Views
BIG DOG
Spring spacers .
« on: December 15, 2007, 03:00:08 PM »
My understanding is if I put in a 1/2" spring spacer I will get 1" of lift with 1" I will get 2" of lift 1.5" will give 3" is this true ... is this true?? So if I wanted 2" of lift I would put in a 1" spring spacer in the front and a 2" spring spacer in the back.
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
Re: Spring spacers .
« Reply #1 on: December 15, 2007, 03:09:56 PM »
No I don't believe thats true. my 1 & 1/8th" spacers lifted about 1.5" total up front. in the rear the spacer lift is exactly how much it will lift
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
kingzoo
« Reply #2 on: December 15, 2007, 03:32:27 PM »
  1.5 inch spacers gives 2 inches of lift in the front.You will need 2 inch to get 2 inch in the rear.
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: December 15, 2007, 05:56:14 PM »
kingzoo is dead on, 1.5" in front and 2" in back. I sell this combo if interested.
3" Masterkit1 body lift
Custom strut spacers
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #4 on: December 30, 2007, 06:36:51 PM »
 I would like to add some 2" spacers. Is this a simple procedure?  Is there any welding or other modification involved?  I would like to add some 2" spacers.  Do you need special tools?  How long does it usually take?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline whateverworks
  • 110
« Reply #5 on: December 31, 2007, 06:44:19 AM »
I can do a spacer lift on a Kick in about 4 hours. Mind you I have done this a few times and know what I might be getting into... like rusted and breaking bolts and what not.
You can put the spacers in the rear by simply disconecting the shocks and dropping the rear axle with a jack while the reat of the truck sits on stands.
The front on the other hand is alot more involved as the sway bar has to be disconected along with the calipers and top strut mount. Be careful lowering the a-arms and do this slowly to avoid injury or taking out the neighbours brick wall with the coil spring going for a fly across the driveway. Lots of tension on the front coils.
Kelly
Offline jeff1997
  • 1228
  • 27
« Reply #6 on: December 31, 2007, 07:51:55 AM »
Kelly
[/quote]Two words, SPRING COMPRESSER! You will need it to get the spring back in and it makes removal a little easier too.
  • 110
« Reply #7 on: December 31, 2007, 08:03:37 AM »
Hey Jeff
Long time no chat...
I never had to use a coil compressor my self. Just had to disconect all the crap and pull on the a-arms and in went the coil spacers. One less tool I had to buy.
Send me a pm and if yer not busy tomorow maybe we can find a place thats open for coffee.
I'm in Brampton.
Kelly
MaD.72
« Reply #8 on: December 31, 2007, 08:28:36 AM »
No need for a spring compresors.....First remove the free/ lock then the snap ring, then the calibor and don't forget the ABS sensor if you have one, after that place a jack under the A arm and unscrew the top of the strut and unscrew the swaybar.....after that lower the jack slowy until the spring is free..... :)
