Tracker samuri t-case install???
  • 10 Replies
  • 3650 Views
Offline nevadasmith
  • 112
  • hey, wait wait I got a new idea!
« on: December 16, 2007, 09:25:31 AM »
I have seen 5 or 6 trackers/sidekicks on the net now, that claim to run samuri t-case is there a way to do this with out using the OTT kicker setup I don't want any shoter rear drive shaft but I would love the high range reduction? but funds are tight and can't aford $700+driveshafts for the OTT kicker setup, so if you have sugestions i'm interested
thanks for the help!
92 hardtop removable + swampers + 2.5" lift+ locker+ onboard air
Offline locjaw
  • 2045
  • 22
Re: Tracker samuri t-case install???
« Reply #1 on: December 16, 2007, 07:04:19 PM »
the guys that are not using some kind of "doubler" have probably used a 2wd tracker tranny then built a custom mountfor the samauri t-case . 3 custom drivelines and a new hole in the transmission tunnel and your in business
it's an option that has crossed my mind too
gearing problems would be a thing of the past
i'm supprised there aint any vendors that have capitolized on this great idea
jason
ZUKTOY
« Reply #2 on: December 17, 2007, 01:12:50 PM »
Prolly wouldn't be that bad if you strettttcccchhheeed  your wheelbase.
Offline Spitfire Rick
  • 123
  • fun lovin criminal
« Reply #3 on: December 17, 2007, 06:46:11 PM »
Ive got a 4dr tracker that Im putting a samurai t/c right behind the tracker t/c Ive done this on another rig& it works sweet
If I have to understand don't bother explaining
Offline ToyYoda
  • 226
« Reply #4 on: December 17, 2007, 07:51:25 PM »
If you run a "dual" t/c isn't your drive shaft " Sami behind Tracker" a little short? It can't be much longer than 12"-14" long. How are you getting wheel travel? And if you do run 2 t/c's can you please take a few pic's as I would like to see this as im sure other would too. Thanx
  • 123
« Reply #5 on: December 18, 2007, 05:56:38 PM »
the rig Im running the dual case on is a samurai frame w/ a 4 link ft & a 3 link rear w/ a 89 " wheel base, a 1.6 16v 5spd & the tracker/ sami  t/cs the rear drive shaft is about 22 "long flange to yoke I have 34 "tractor bars  welded rear & I beat this thing & have had no problems. the "drive shaft"  between has to be lined up right and the cases mounted  together solid.. the rig Im putting  a auto trans version  into has a 106 wheel base so I dont see any problems
« Last Edit: December 18, 2007, 06:39:26 PM by Spitfire Rick »
  • 123
kingzoo
« Reply #8 on: December 19, 2007, 01:37:08 PM »
    I should be so lucky!
« Reply #9 on: December 19, 2007, 07:07:37 PM »
I cant seem to get pics to post  but here some photobucket
Is that a Fiat?
Nice.  Front end looks evil.  :)
  • 123
« Reply #10 on: December 20, 2007, 12:32:37 AM »
its Triumph Spitfire.. Ive owned the yellow one in the Background since  1980
