Vehicle Speed Sensor
  • 1700 Views
Offline olija
  • 770
    • Check out my cardomain
« on: December 17, 2007, 10:49:07 PM »
My VSS is malfunctioning. Is there any way to fix it or is it a remove/replace item? Is it located on the inside or on the outside of the transfer case?
Re: Vehicle Speed Sensor
« Reply #1 on: December 18, 2007, 04:38:53 AM »
If its a first gen vehicle then its mounted on the rear of the speedo. The switch is a reed switch. If you're handy with a soldering iron then you should be able to source one from an electronics shop. Make sure that the speedo cable and drive gear are OK first though. 2nd gen use a Hall Effect switch on the t-case, these are usually very reliable so check the wiring before before buying a new one.
