Weber Carb Setup Question
  • 2354 Views
MiniFJ
« on: December 20, 2007, 04:35:11 PM »
I'm running a Weber 32/36 on my bone stock 1.3. I'm wondering what jet combo should I be running with this setup and if anyone has anymore info on getting it dialed in????
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Weber Carb Setup Question
« Reply #1 on: December 21, 2007, 04:26:24 AM »
Try a search for weber at Ack's FAQ (the link is in my signature). You will find several documents and links that shoould get you going in the right direction.
Ack
MiniFJ
« Reply #2 on: December 21, 2007, 08:41:11 AM »
Thanks for the link and the quick reply. That was the info I was looking for.
MiniFJ
« Reply #3 on: December 26, 2007, 05:42:03 PM »
Just updating....
I switched out some of the jets on my Weber tonight. Thing runs great now... way more power then before. I did find that a "50" primary idle jet was a little too big for a stocker, the plugs were wet after two minutes of running it. So I knock it down to a "40" and the thing ran great. So here is what worked:
40 primary idle jet
50 secondary idle jet
160 primary air jet
170 secondary air jet
135 primary fuel jet
140 secondary fuel jet
1 3/4 turns out on the idle/air screw
Hope this helps someone looking to get and tune a weber. Happy Wheelin'  ::)
