more speekers.....
  • 2358 Views
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
more speekers.....
« on: December 24, 2007, 01:32:00 PM »
well, i needed some more high's with my newly added subwoofers, so i got some more tweeters.....heres some pics
Re: more speekers.....
« Reply #1 on: December 26, 2007, 01:15:46 PM »
That looks pretty good up there on the dash.  :)
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #2 on: December 26, 2007, 05:10:28 PM »
thanx man... i used to be a painter at a bus factory, and this is some abs plastic which i scored while i was there...put it to some good use......knew id use it sometime....quit the bus factory 2 yrs ago...but i just drilled some real little holes thru the duct work and a small hole in the top of the dash, the opening has a lip on it, so i cut the piece to fil inside the lip...to attach it i used a small bead of silicone, if i wanna remove it it will be simple, and there is no fastners showing
phloop
« Reply #3 on: December 26, 2007, 05:31:02 PM »
How's the hearing? ???
Offline locjaw
  • 2045
  • 22
« Reply #4 on: December 27, 2007, 08:49:58 AM »
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #5 on: December 27, 2007, 06:56:01 PM »
well, im just glad that i can actually hear some tunes while driving down the road instead of my flowmaster, tires, and soft top noise....im sure its gonna be pissin the neighbors off, thou.....O WELL :P
