86 zuk with ck eng light
  • 1510 Views
bull elk
« on: December 26, 2007, 08:12:03 PM »
new to this whole deal and needin advice.i have 86 zuk with 94 -1.6 swap it keeps shorting out ecm and the only code is for engine coolant sensor.i put in a new sensor and 2 different ecms? any one got any ideas ?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 86 zuk with ck eng light
« Reply #1 on: December 27, 2007, 03:24:24 AM »
Try a search for engine wiring diagram at acks's FAQ.  Unfortunately, I have discovered that the six different engine types have the same injection type in the link heading!
OOPS! I need to fix that tonight!
Select one of the two 1.6 engines type that you have. One of those is your wiring diagram.
Compare it to what you have - making SURE that the grounds are all tight.
Hope that this helps!
Ack
