TinTop JX w/ AC: How many made, limited numbers?
  • 2466 Views
MiniFJ
« on: December 29, 2007, 04:29:57 PM »
I just picked up a bone stock '87 Tin Top JX w/ A/C. Just wondering how many Tin Tops w/ A/C were made, link with the info or any info on it and what is something like this going for these days. I own and know about samurai, I've heard that Tin Tops w/ A/C are rare but don’t know for sure and I’m new to the pricing game when it comes down to Samurais. Everything does work, runs and drives but needs a little help.
Any info is good info to me. Thanks for your help.
Offline SnoFalls
  • 1358
Re: TinTop JX w/ AC: How many made, limited numbers?
« Reply #1 on: December 30, 2007, 02:31:01 AM »
IIRC, A/C on samis was a dealer installed option, so "production" numbers are probably hard to come by.
MiniFJ
« Reply #2 on: December 30, 2007, 06:30:02 AM »
See, I something new every day! I didn't A/C was dealer installed. Thanks for the info
MiniFJ
« Reply #3 on: January 01, 2008, 04:48:17 PM »
One more question....
Are the a/c systems on the samurai's R12 or 134?? The a/c blows cold but should be blowing colder.
Offline tipover
  • 422
« Reply #4 on: January 01, 2008, 07:45:48 PM »
R12.  I have put in several A/C in sammys.  If everything works right it should be decent in a hard top. They really can't put enough CFM to cool a soft top in hot weather. I live in California's central valley.  An A/c properly installed has a wire to the back of the instument cluster on one of the studs on the cucuits that turns the compressor off when it reaches a certain temperature.  In my experience it usually stops the A/C when you need it the most.  it is a safety for the engine to prevent it from over heating.  I usually keep that connector unhooked unless I let the wife drive it.  the connector is usually to the left of the stereo.  there I gave you more info than you asked for.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
MiniFJ
« Reply #5 on: January 05, 2008, 06:29:11 AM »
Thank you. More info is good and that was a good piece of info to have.
