lockrite lockers.
  • 1807 Views
bruce5385
lockrite lockers.
« on: December 31, 2007, 05:51:07 AM »
will the lockrite locker for suzuki samurai fit in the rear third member of a sidekick?
Offline whateverworks
  • 110
Re: lockrite lockers.
« Reply #1 on: December 31, 2007, 06:34:56 AM »
No they are slightly different. Part number for the Sammi without sidegears is the Lock Right 1510 and the set for the 'Kicks is the 1512 without side gears.
Kelly
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #2 on: December 31, 2007, 02:19:23 PM »
I have the samurai lockrite in the back of lil Suzy, It is slightly narrower than the sidekick but other than that exactly the same. I bought the locker without side gears and new Samurai side gears from Brent at TrailTough. The lockers have to be set up properly but I was told that the quality is better on the Samurai than the Sidekick by Brent. He set it up in a new carrier for me, so I don't know the exact install specs but I know it has to do with installing the proper thickness of thrust washers.
Student of Now Master of Then
phloop
« Reply #3 on: December 31, 2007, 02:58:09 PM »
Yes it will fit but you need to use the stock cross pins. When I installed one in my hybrid rear the pins kept moving out and rattling on the pinion so I had to pull it apart and install the sidekick cross pin's which use roll pins to retain them.
