Haynes or chilton?
  • 1951 Views
Offline Mythose
  • 361
Haynes or chilton?
« on: June 13, 2005, 05:46:33 AM »
hay i am going to rebuild an 8V motor starting on the 15th, just bought all the parts-  and want to know is the haynes or chilton better information, its all basicaly the same one motor to anouther but I want to check clearances and such.
And yes I will start a post tomorrow, with pics every step of the way, all the way to reseating the valves, and honing the cylendars if nesecary. "and if i can find my hone"  and its been about 3 years sence last I riped into a motor, so its about time. and then I wont have to worrie about it.
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
Re: Haynes or chilton?
« Reply #1 on: June 13, 2005, 06:03:58 AM »
Here's an older thread with the exact topic title (except for the Question Mark :P)
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1117541933;start=
[/url]
[/url]
Offline Mythose
  • 361
« Reply #2 on: June 13, 2005, 06:56:26 AM »
Thank you much,  could be a burnt valuve and not rings,  any way i have a doner motor if its a burn vaulve. but we will se I should have time today to tear it apart,  and get a look at the inside, then I will know.
 but i got  new stem seals for the valuves anyway.
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #3 on: June 13, 2005, 07:14:53 AM »
Personally I have Chilton, but then check that other thread...
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #4 on: June 13, 2005, 01:15:45 PM »
Mythose,
Good luck :P and don't forget the pics and the commentary ;D
[/url]
[/url]
Offline MaineZuke
  • 6
« Reply #5 on: June 15, 2005, 07:14:45 AM »
