which fuel pump for a 1.6L ???
  • 1972 Views
87 sammi
« on: January 08, 2008, 08:00:33 PM »
i did the 1.6 8v swap in my 87 samurai and i am trying to figure out what fuel pump to use. the motor calls for one that puts out 35-40 psi. Is there any vehicles that have an inline pump that puts that out that would be a practical swap? if not, any recommendations as to which one to buy? Thanks!!
phloop
Re: which fuel pump for a 1.6L ???
« Reply #1 on: January 08, 2008, 08:18:17 PM »
If you kept the FI you need a high pressure pump and if you had a carb and kept it you will need a low pressure pump. Any auto parts store should have these, just a generic replacement part.
Help any?
87 sammi
« Reply #2 on: January 08, 2008, 08:28:06 PM »
its a FI fyi
phloop
« Reply #3 on: January 08, 2008, 08:43:50 PM »
OK then you need the high PSI unit. Trali tough has it for $80 but as I mentioned, you can pick it up at an auto parts store also.
Offline RHodge
  • 523
« Reply #4 on: January 08, 2008, 08:50:15 PM »
mid 80's subarus (FI ones) have an exturnal pump that I used on a 510
should be in that range and they don't go bad much thay are a rotory pump
Ryan
