4 link coil spring help
  • 2564 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: January 09, 2008, 09:12:44 PM »
ok im putting a custom 4 link on my Suzuki i got the QA1 14 inch springs. the problem i cant find a mounting kit or bracket to solid mount it to my rig. is their a company that makes a bucket kit . if not how did some of u go about mounting it so the axle will pull on it as it drops. i want it solidly mounted to the frame and the axle. please help.
Offline DRAGGINZUZU
  • 141
Re: 4 link coil spring help
« Reply #1 on: January 10, 2008, 04:37:47 AM »
http://bluetorchfab.com/
They have all the brackets you need for a coil kit. Some other guys use them. there not to bad on price either. I made my own hope it helps.
Its not what you buy but what you build
 Tony
« Reply #2 on: January 10, 2008, 04:44:59 AM »
You shouldn't have to retain the spring top and bottom. The spring will wear out quite quickly if it is stretched, either use dislocation cones or configure the shock travel so the spring can't fall out.
