Master cylinder upgrade!
  • 1698 Views
doughnutguy82
« on: January 11, 2008, 12:17:51 PM »
Hey  yall i gots a question for ya. I have a 87 jx with toyota axles under it. The brakes work ok but im thinking that i need to get a bigger master cylinder for the axles.
i have a *8 inch front and a LC rear with 4 wheel cylinders. i dont kn ow if my master cylinder is able to push enough fluid for my brakes and im hoping some one here has had the same problem and mite have a solution for me, or some good advise.
Also has anyone had a porportioning valve go out and if so how did the brakes act?
thanks a bunch.
kingzoo
Re: Master cylinder upgrade!
« Reply #1 on: January 11, 2008, 04:18:03 PM »
   When my proportioning valve let go I lost my back brakes.I thought I had lost a wheel cylinder or something but it was the valve.
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #2 on: January 11, 2008, 04:46:59 PM »
http://www.zukikrawlers.com/showthread.php?t=10552&page=4
Alot of good info in this buildup. But a good write up on swapping master cylinders.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
doughnutguy82
« Reply #3 on: January 11, 2008, 09:48:33 PM »
thanks for the insite about the mastercylinder. I have one out of a f150 and it has a very similar mounting setup too, so i mite try it.
thanks for the link it has alot of good stuff on it that i will keep in mind for my future plans   :)
