Tracker Shift Knob
  • 17 Replies
  • 5367 Views
Offline rockcrawler
  • I'll go through it again
    • Xtremeoffroading
Tracker Shift Knob
« on: October 31, 2004, 02:23:59 AM »
Does anybody know how to take off a shift knob of a 93' Geo Tracker?
Xtremeoffroading- It's Not Hardcore... Until The Hard Part Is Done!
Re: Tracker Shift Knob
« Reply #1 on: October 31, 2004, 02:26:55 AM »
The 4WD knob has a screw in
the back side of it.
I'm not sure how the trans
shifter is on Track/Kick, Sammies
are threaded on
Offline rockcrawler
    • Xtremeoffroading
« Reply #2 on: October 31, 2004, 02:30:07 AM »
thanks anyway
Offline rockcrawler
    • Xtremeoffroading
« Reply #3 on: October 31, 2004, 02:31:39 AM »
cause we tried it and the Tran. shift knob spins off we thought but to tight. Should we go ahead and turn it?
« Reply #4 on: October 31, 2004, 02:34:54 AM »
Do you have a new knob
for it, or did you need to
get the shifter handle off
for a body lift ???
I would just turn it counter
clockwise until it came off,
it's tight so it stays in the
right spot to match the gear
shift pattern
Offline rockcrawler
    • Xtremeoffroading
« Reply #5 on: October 31, 2004, 02:39:09 AM »
I'm putting a new one on.
« Reply #6 on: October 31, 2004, 02:47:57 AM »
Well then, your not going hurt
the shifter handle, so twist away
;D
PS
Try a big pair of Vice-Grips, as long
as you don't need the knob in the
future the teeth marks don't matter
« Last Edit: October 31, 2004, 02:49:19 AM by wildgoody »
« Reply #7 on: October 31, 2004, 02:50:04 AM »
What did you get, a Rock Knob ???
Offline rockcrawler
    • Xtremeoffroading
« Reply #8 on: October 31, 2004, 02:53:07 AM »
No, just a knob from Auto Zone, a LED shift knob. I guess it's a regular size but the tip on the bottom of it is pretty small.
Offline rockcrawler
    • Xtremeoffroading
« Reply #9 on: October 31, 2004, 02:54:02 AM »
Do you have a parts manual on a 93' Geo Tracker for changing a shift knob?
« Reply #10 on: October 31, 2004, 02:59:23 AM »
No, sorry
I like to go to the wrecking yard
and destroy or figure out how a
part comes off before I do my own
stuff, that is if I don't figure it out
first
Offline 1bigtracker
  • 3409
« Reply #11 on: October 31, 2004, 03:14:20 AM »
the shift knob should just screw off,  i took mine off and never looked back,  A hurst T handle is soo much better!
stu
Offline rockcrawler
    • Xtremeoffroading
« Reply #12 on: October 31, 2004, 04:27:28 AM »
Yeah, it does screw off but we had to cut part of the knob off and it just screw off. That new shift knob we put on there looks really cool. It has a LED blue light, the gears light up on it.
Offline explosivo
  • 3157
« Reply #13 on: October 31, 2004, 05:01:12 AM »
Post some pics, man! Sounds neat if it is black with glowing gear numbers. :)
omghi2.us[/url]
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #14 on: October 31, 2004, 07:17:22 AM »
PICs must accompany all ricer upgrades. This is a rule of Zukiworld.... ::)
steveo
