gear curious
  • 1655 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
gear curious
« on: November 01, 2004, 02:05:38 AM »
How hard is to switch gears in the transfer case?
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline DoctorD
  • 68
  • No such thing as too many toys!
Re: gear curious
« Reply #1 on: November 01, 2004, 02:28:55 AM »
Not too hard!  I did mine about a month ago, I had to buy a new puller to get the bearings and gears off, but a $15 GI Joe's special did the trick.  To put the bearings back on, I put the shafts in the freezer, and heated the bearings with my heat gun, and they just slid together with finger pressure.  I think it took me about 4 or 5 hours all together.  But I'm slooooow!
D
In search of new toy
Re: gear curious
« Reply #2 on: November 01, 2004, 02:58:02 AM »
It took a friend and I about 3 hours and a gear puller.  We used a deepwell socket and a piece of wood to put the bearings back together instead of the freezer trick.  It's still running fine so I guess we did a good job.
Just remember, if you go with the larger gears and need to check T-Case clearance, check BOTH sides.  The instructions I had only showed them checking one side.  I pulled my case back apart two times trying to figure out why it was locking up when I bolted everything together before I figured out what was wrong.  Yea, I'm a little slow sometimes.   :P
