Rocky Road Spoa Lift Help (new guy)
  • 13 Replies
  • 3606 Views
tdub9899
« on: January 24, 2008, 06:44:14 PM »
I had my axles welded at a shop and they were supposed to weld the front  Pads perralel to the bottom, and the rear the pinion is 3 deg. up     When i bolted them up, the rear looks level and the front is pointing upwards at a steep angle, is this normal?
Re: Rocky Road Spoa Lift Help (new guy)
« Reply #1 on: January 24, 2008, 07:49:26 PM »
No, not normally.  On mine they are both pretty much level.  Did they leave the lower spring pads on or did they cut them off?
tdub9899
« Reply #2 on: January 24, 2008, 08:03:23 PM »
they left the lowers on, and the new perches actually weld to the bottom ones..... great i guess they screwed up huh?
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #3 on: January 25, 2008, 10:37:08 AM »
Call Rocky Road and ask if there is a difference between the front and rear SPOA perches, then measure what you have.  HTH
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
« Reply #4 on: January 25, 2008, 01:08:26 PM »
Did they install the perch backwards, meaning the front of the perch was installed towards the rear?  This would screw things up a tad bit.
« Reply #5 on: January 25, 2008, 08:30:24 PM »
Park on a level surface and take a level to the lower pad.  It should be even with the ground.  :)
tdub9899
« Reply #6 on: January 25, 2008, 09:43:26 PM »
thanks... ill try that, also i bolted the front driveline on no prob and the rear wont go on unless all the way extended!!(with spacer)  so i think they might have put the pads on backwards.
« Reply #7 on: January 28, 2008, 12:11:34 AM »
Not necessarily.  I didn't need to put a spacer on my rear drive-line, neither did one of the Sammy's in the club.  I didn't need a spacer until I slid the front axle forward.
tdub9899
« Reply #8 on: January 28, 2008, 01:30:28 AM »
what does your pinion angle look like, mine is flat so thats got to be the reason it wont hook up?  I was thinking about 3 degree shims.  how far is your slip yoke extended?
« Reply #9 on: January 28, 2008, 12:14:52 PM »
I'm not saying that a spacer isn't needed, just sometimes it isn't.  I think it depends on your pads and how much arch you have on your springs.  My pinion angle is pretty much flat front and rear.
The proper way to fix the problem is flex out and re-size your drive shaft properly.  The spacers just easier.  :)
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #10 on: January 28, 2008, 03:31:07 PM »
Hi:
The new SPOA front axle perch spring faces are supposed to be exactly parallel to the faces of the OEM perches.   If you plan to drive this truck on the road, it HAS to be this way.  Changing the pinion angle like that will seriously mess up the caster angle and make the truck hard to handle on the road.
Also, unless I am mistaken, the passenger side front perch is specially cut to fit on the sloping edge of the dif housing so it will line up position-wise with the OEM perch.  That's the way it was for my Breeze SPOA.
Check out the following links:
http://www.4x4wire.com/toyota/tech/driveline/
http://www.4xshaft.com/driveline101.html
I'd take the axles back to those cowboys and tell them to reweld them parallel for free - unless they want to buy you a Double-cardan driveshaft and cut the knuckles to fix the caster problem for free...
BTW:  Didn't the perches come with installation instructions?
« Last Edit: January 28, 2008, 03:35:53 PM by ack »
Ack
tdub9899
« Reply #11 on: February 13, 2008, 11:24:32 PM »
Not sure if you will get this but.... Are the rear pads suppose to be welded parallel like the front? Or should i go 3 degrees above that?
Hi:
« Reply #12 on: February 14, 2008, 12:22:48 AM »
I would just go parallel, just like the front.
tdub9899
« Reply #13 on: February 14, 2008, 01:22:33 AM »
thanks
