tire rub
  • 10 Replies
  • 2541 Views
Nicksidekickin
tire rub
« on: January 25, 2008, 10:51:40 AM »
how bad would 30x9.50 tires on 15x8 with 3 1/4 backspacing rub on my sidekick it has a 2inch suspension lift on it?
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
Re: tire rub
« Reply #1 on: January 25, 2008, 01:51:06 PM »
i had 31x10.50x15s on a 15x8 rim with 3.75 bs with 2 in bl and i just had to adjust the stops a little not really enough to notice
Nicksidekickin
Re: tire rub
« Reply #2 on: January 26, 2008, 04:11:52 PM »
thanks if yours didnt rub bad then 30s shouldnt at all
Offline 95tracker
  • 104
Re: tire rub
« Reply #3 on: January 28, 2008, 07:07:47 PM »
I would think that you would be alright i did have to been my inner fenders a little but i didnt have to do any cutting to the outside of the fender.
Offline olija
  • 770
    • Check out my cardomain
Re: tire rub
« Reply #4 on: January 29, 2008, 08:16:52 PM »
I have 30x9.50's on 15x7 with 3.75" backspacing and all of them cleared the fenders with no trimming except the front left tire. It just rubbed a smidge on the back of the front fender, on the inside, but only with the wheel cranked and the suspension compressed. All I did was unscrew the plastic inner liner, bend the metal behind it back with a hammer, then re-attach the plastic using a zip-tie. No more rub.
Nicksidekickin
Re: tire rub
« Reply #5 on: January 30, 2008, 07:29:59 AM »
i was planning on bending the metal back in the fender wheel just to give a little more clearance.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: tire rub
« Reply #6 on: January 30, 2008, 12:15:19 PM »
Yup, that's where it starts.  Once you get up to the 33's, you don't even flinch, when you whip out the sawzall, and commence with the slicing and dicing of the sheet-metal.  I remember how nervous I was when I took the saw to the body for the first time - opening up a hole through the fender for the snorkel.  I was terrified!  Now, I just jump into it.  The sawzall is your number-one artistic tool for sheet-metal mods!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Nicksidekickin
Re: tire rub
« Reply #7 on: January 30, 2008, 07:06:27 PM »
I aint that far yet my bubby has done that to his kick and his sammy i still have to drive mine to work for now but in do time.
Offline olija
  • 770
Re: tire rub
« Reply #8 on: January 30, 2008, 08:02:52 PM »
Once it's dented and/or scratched you may as well just cut it anyway. I mean, there's less material to get damaged, right??? ::)
Nicksidekickin
Re: tire rub
« Reply #9 on: January 31, 2008, 05:09:30 AM »
hahaha yeah i've really done good when i've been on the trails i've only got one small scartch on the left side and it will buff out lol
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: tire rub
« Reply #10 on: January 31, 2008, 09:45:44 AM »
No, no, no, no, no...you've got it all wrong!  NEVER buff those out!
Chicks dig body damage!
 ;) :laugh:
Bob
