Toyota axle swap help!!
  • 2837 Views
wildphil69
« on: January 26, 2008, 08:26:41 PM »
Has anyone done the toyota axle swap? Do you move the front right spring perch?
Offline whateverworks
  • 110
Re: Toyota axle swap help!!
« Reply #1 on: January 27, 2008, 06:40:24 AM »
Ummmm... I have always wanted to say this...
DO A SEARCH!!! LOL
Kelly
Offline Amilla
  • 1076
« Reply #2 on: January 27, 2008, 10:39:04 AM »
You move both of the perches in, you move the in somthing like 5/8ths or somthing very close to that.  Make it a lot easyer on your self and get the sky toyota to suzuki axle kit. Then just measure how for the suzuki perches are (from the center pin on the perchs).  Weld the perches on the toyota axle at that same width...BLAM your good to go!
If you need any more info, im doing a build up on my 88 sami.  The build up includes a T-yot axle swap.
Its in build diaries,How to, DIY section
88 Samurai build-up
Amilla
wildphil69
« Reply #3 on: January 28, 2008, 02:24:17 PM »
Well im not going to spend $120 on that dor a spring perch and u-bolts when i can get everything for $50
Offline Amilla
  • 1076
« Reply #4 on: January 29, 2008, 10:33:27 AM »
Alright, if you don't want to buy anything, here is the next best thing...make it!
Here is the DIY version of the sky man kit.
This one goes on the short side of the axle, you just weld it on top of the perch and moved in to match the width of the Suzuki axle.
If anyone is wanted to go this route and make them i can e-mail this sheet to if
(This pic doesn't look too high quality)
Hope this helps some what
Amilla
MaD.72
« Reply #5 on: January 29, 2008, 02:27:30 PM »
can you e-mail it to me???
