Tracker Pitman arm?
  • 18 Replies
  • 6542 Views
Offline Fity
  • 49
Re: Tracker Pitman arm?
« Reply #15 on: June 14, 2005, 11:43:36 AM »
If your after a cheap drop pitman arm from a wrecker, one from an early 80's Toyota Tarago van has the same spline as a power steer Vit and same shape as the 3" drop pitman arms available.  The only difference is the tapered hole is larger, so a tapered bush is needed or a larger tie rod end.  $20 cheap.   ;D
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #16 on: June 14, 2005, 04:30:06 PM »
hmmmm... gotta check that out..... the hole aint no big deal as I need to drill it out to 3/4" for the heim joint anyway.
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline Fity
  • 49
« Reply #17 on: June 14, 2005, 05:27:26 PM »
I am pretty sure that you won't even need to drill it out as the small end of the taper is around 3/4" :)
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #18 on: June 15, 2005, 06:07:28 AM »
Hey Flex,
To stop the confusion these guys are giving you just go get a Sammy so you can get all the parts they're posting here ;D ;D ;D
[/url]
[/url]
