Tracker Pitman arm?
  • 18 Replies
  • 6401 Views
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
Tracker Pitman arm?
« on: June 12, 2005, 04:31:28 PM »
is there another pitman arm that fits a tracker power steering box? if so which?
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline Natebert
  • 1098
Re: Tracker Pitman arm?
« Reply #1 on: June 12, 2005, 04:35:26 PM »
I think that Calmini, Hawk, and Sky all have aftermarket pitman arms for track/kicks
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: June 13, 2005, 04:52:07 AM »
Nate?  What're you smoking, dude?   ???
I haven't seen ANY replacement Pitman arms, but Calmini makes an Idler Arm Brace (which goes on the opposite end of the linkage from the Pitman Arm), and Sky makes a HUGE, BEEFY, MUST-HAVE Idler Arm, that replaces the stock Idler Arm.
You Can use both the Sky Idler Arm, and the Calmini Idler Arm Brace at the same time.
« Last Edit: June 13, 2005, 04:52:50 AM by Bobzooki »
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline 1bigtracker
  • 3409
« Reply #3 on: June 13, 2005, 06:26:06 AM »
i don't know what he smoking but
http://www.puresuzuki.com/pitman_arm.htm
i wish he would share ;D
stu
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: June 13, 2005, 06:40:38 AM »
stu
Umm, Stu, that's a Samurai Pitman arm, not a Tracker Pitman arm...
Bob
« Reply #5 on: June 13, 2005, 06:43:59 AM »
Isn't that a Sami drop arm? I could not find one for a Kick/Tracker  :-/
Offline 1bigtracker
  • 3409
« Reply #6 on: June 13, 2005, 10:01:25 AM »
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #7 on: June 13, 2005, 01:02:29 PM »
opps
http://www.puresuzuki.com/kick_pitman_arm.htm
stu
Im guessing thats what he was looking for. A drop pitman for a kick box.
Mike
Offline Natebert
  • 1098
« Reply #8 on: June 13, 2005, 02:10:44 PM »
Bob,
I'm not smoking nothing, I shouldn't be...
They all offer kick pitman arms, don't they?
Pretty sure I've seen the drop one from Calmini (thinking about ording one).
Pretty sure Hawk's got a bunch of stocky type pitman arms , plus I bet he's got the inside scooop on another make which would work too.
I'm also pretty sure Sky's got a Beefcake drop pitman arm you could order if you ask.
Maybe you should lay off hording the plumbwine and start sharing!
« Last Edit: June 13, 2005, 02:18:40 PM by natebert »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: June 13, 2005, 02:56:23 PM »
Don't forget about Trail Tough too!
http://www.trailtough.com/steering_components.htm
See the last line in the top product in that list..
But maybe our original poster is wondering what kind of pick and pull pitman arms might fit a track kick..
That...
I have no idea.
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: June 14, 2005, 01:47:49 AM »
HELLO???
From The Calmini Web Page You linked to:
Arm is for the Samurai with a Sidekick power steering conversion and the factory steering system.
Why would you need a drop-pitman arm on a Kick? ???
The Trail-Tough stuff is also for a KICK STEERING BOX ON A SAMURAI.
« Last Edit: June 14, 2005, 01:49:02 AM by Bobzooki »
Bob
Offline Natebert
  • 1098
« Reply #11 on: June 14, 2005, 03:04:50 AM »
HELLO???
If you buy the 'sidekick power steering conversion' from either calmini or TT you get a kick pump and a kick box.  Then you can put a drop pitman arm on it, a drop pitman arm on a kick box....A different than stock pitman arm on a kick box.  Sound like it'd work on a Sidekick, not just a Sammy.
I'd think that everybody who's lifted their kicks more than 4 or 5 inches from the frame, should relocate their idler and pitman arm attachment points to keep their steering angles correct.  Even if you've swapped the ball joints on top, you're still at a pretty nasty angle.
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #12 on: June 14, 2005, 08:27:36 AM »
good info, I got the toy axles in the tracker now, hi-steer setup, 3/4" heims and 1" 1/4"wall tubing for steering, I think I may need to drop the arm a bit but damn..... $120 for an arm... wow. stock arm aint that bad..... yet.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #13 on: June 14, 2005, 08:57:06 AM »
I dunno...
When you add the Calmini suspension lift, you do not change the pivot point, and you lengthen the links to the steering knuckle, to fix your toe-in, so I don't think that lowering the pitman arm, and idler arm would be a good thing...
« Last Edit: June 14, 2005, 09:02:02 AM by Bobzooki »
Bob
Offline 1bigtracker
  • 3409
« Reply #14 on: June 14, 2005, 10:23:52 AM »
HELLO???
i can think of one or two:
stu
« Last Edit: June 14, 2005, 10:24:18 AM by 1bigtracker »
  ÂÂÂÂÂÂÂ
