Regearing options (possible sticky?)
  • 1849 Views
Offline olija
  • 770
    • Check out my cardomain
« on: January 30, 2008, 08:57:56 PM »
I'm looking into some sort of gearing options for my Sidekick, not too interested in r&p's, so I've found a few things:
Calmini has 4.24:1 t-case gears for $850
Trailtough has 4.24:1 gears regular $850, currently on sale for $650
OTT has the Kicker 1 (Sidekick transmission/first half of transfer case to half of a Sammy case) for $600
OTT also has the Kicker 2 (Sidekick transmission to Toyota t-case) for $675
Rocky Road seems to have stopped selling their gears
Is it possible to put a Sammy case behind a 2WD TrackKick transmission? So far that is looking like my best bet if I don't want to spend a huge wad of cash on this beast. I just want to be able to crawl with 31's.
Offline Amilla
  • 1076
Re: Regearing options (possible sticky?)
« Reply #1 on: January 30, 2008, 10:39:16 PM »
Are the 2wd kick trannys close to the same gear ratios as the sammis?
If they are close I'm sure you could slam a sammi case behind that tranny.
A divorced T-case is definitely nice, that fact that you don't have to re-gear your R&P's
I would like to see how this comes out.
Amilla
Offline olija
  • 770
« Reply #2 on: January 31, 2008, 09:34:35 PM »
After doing a little research, I would have to say, yes, they do have the same ratios and it is possible to put a Sammy case behind the Kick 2wd tranny. However, it's still kind of tricky cause both are not the easiest to find.
Offline Armour
  • 360
« Reply #3 on: January 31, 2008, 10:11:32 PM »
Sorry Guys but what exactly is OTT?
