Check engine light. Reading codes
  • 8328 Views
Offline BLK_ARMR
  • 175
  • Herculiner All The Way!!
« on: February 02, 2008, 01:46:29 PM »
I have a 94 Tracker.  CEL is on.  It still runs fine.  I was trying to check the code and see what it's throwing, but can't get it to flash.
This is the connector I found under the hood.  Is this the right one? (white plug)
This is what's under my dash beside the fuse box.
Any input?  I tried jumping 2 and 3 on the white plug and then turning the key on.  Do you turn it to Acc, or all the way to ON. Acc gave me nothing.  When all the way to ON, it just came on and stayed on, which IIRC is what it always does, like when you get ready to start the vehicle.
I also found this switch recently.  Wasn't sure what it was.  After searching, it seems it may be the CEL switch?  If so, what exactly does it do when you flip it?  Just turn the light off, or what?  It was under the dash, kinda right behind the speaker on the driver's side.
Any input is greatly appreciated.
93 Tracker
Coated in **HERCULINER**
2pc Hard Top, Flares, 3" Body Lift, 31"x10.50" OTR Muds, 15"x8" Black "Wagon Wheels"
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Check engine light. Reading codes
« Reply #1 on: February 02, 2008, 02:02:43 PM »
In order for the light to flash the check engine light must be off. Switch that switch you are pointing to in the picture then try again
Student of Now Master of Then
Offline BLK_ARMR
  • 175
« Reply #2 on: February 02, 2008, 02:17:05 PM »
Gotcha.  So switch it off, then jump pins 2 and 3 on the white connector?  I assume that's the right one.  What are the connectors under the dash??  Anyone know?
93 Tracker
Offline 89tintop
  • 356
« Reply #3 on: February 02, 2008, 04:17:24 PM »
that is for those people who have those million dollar snap on readers that read obd1's also. sidekicksrock is right on the money as i just had to flick the switch on my 93 to read my trouble codes.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
phloop
« Reply #4 on: February 02, 2008, 06:32:58 PM »
A new question in line with the old one. Where do you find what the flashes mean? And which one of those ports would you plug a reader into? I am thinking it is the gray one, or is that the grey one? :laugh:
Offline ROSS
  • 1412
« Reply #5 on: February 02, 2008, 06:48:00 PM »
the gray one
Offline 89tintop
  • 356
« Reply #6 on: February 02, 2008, 07:01:54 PM »
here you go.--------------------------------------------------------------------------------
I have tried to list every possible Suzuki engine that might be found in one of our vehicles, if you note a wrong code please let me know and a reference where you found the correct code and I'll get it changed. To the best of my research ability, these are correct.
86–95 Samurai, Swift & 89 Sidekick
NOTE: This information does not apply to carberated engines, as they will have a check engine light but don't store codes, so you have to troubleshoot manually to determine which sensor is causing the problem.
DTCs may be accessed by installing a spare fuse into the fuse box diagnostic terminal, located under the LH side of the instrument panel, then turning the ignition On.
90–95 Sidekick
DTCs may be accessed by installing a jumper wire between diagnostic check connector terminals B and C, located in the RH rear of the engine compartment, then turning the ignition On.
96–00
Accessing DTCs must be done through the Data Link Connector (DLC), located under the LH side of the instrument panel, using a Suzuki (Tech-1) scan tool or an OBD II generic scan tool.
Reading trouble codes
The instrument panel Check Engine lamp displays the DTCs. In normal operation the lamp will light when the ignition is turned On. However, two different lamp functions can occur when the engine is started. The lamp may turn off immediately, indicating there is no fault at that time, or stay lit, informing the vehicle operator that there is a system failure. If the lamp stays lit a DTC will be stored in the ECM memory. When a DTC is accessed from the ECM memory the Check Engine lamp will flash in a series, indicating the DTC number. When multiple system failures occur applicable DTCs will be indicated three times each. DTCs will continue to flash as long as the ignition is On, and the diagnostic switch terminals are grounded.
Clearing Codes
DTCs may be erased by disconnecting and isolating the battery ground cable for more than 60 seconds, or after 50 key cycles if the malfunction has not recurred.
On models with OBD II, the DTCs may be cleared with the scan tool, following the tool manufacturer’s instructions.
89–95 SIDEKICK & SAMURAI  w/TBI FUEL INJECTION
12     All Clear (No Fault Detected)
13     O2 Sensor circuit
14     Coolant Temperature Sensor Circuit
15     Coolant Temperature Sensor Circuit
21     Throttle Position Sensor Circuit
22     Throttle Position Sensor Circuit
23     Intake Air Temperature Sensor Circuit
24     Vehicle Speed Sensor Circuit
25     Intake Air Temperature Sensor Circuit
31     Atmospheric Pressure Sensor Circuit
32     Atmospheric Pressure Sensor Circuit
41     Ignition Signal Circuit
42     Crank Angle Sensor Circuit
44     Idle Switch Sensor Circuit
45     Idle Switch Sensor Circuit
51     EGR System & Recirculated Exhaust Gas Temperature Sensor
53     Ground Circuit
54     Fifth Gear Switch Circuit
71     Test Switch Circuit
ON     ECM failure
92–95 SIDEKICK  w/MULTI-POINT FUEL INJ
13    HO2S Circuit
14    ECT Sensor Circuit
15    ECT Sensor Circuit
21    TP Sensor Circuit
22    TP Sensor Circuit
23    IAT Sensor Circuit
24    VSS Circuit
25    Intake Air Sensor Circuit
33    Air Flow Sensor Circuit
34    Air Flow Sensor Circuit
42    CMP Sensor Circuit
44    Idle Switch Circuit
45    Idle Switch Circuit
51    EGR System & REGT Sensor Circuit
52    Fuel Injector
96–98 SIDEKICK & X-90 1.6L ENGINE
P0101    MAF Circuit Performance Problem
P0102    MAF Circuit Voltage Low
P0103    MAF Circuit Voltage High
P0112    IAT Circuit Voltage Low
P0113    IAT Circuit Voltage High
P0117    ECT Circuit Voltage Low
P0118    ECT Circuit Voltage High
P0121    TP Circuit Performance Problem
P0122    TP Circuit Voltage Low
P0123    TP Circuit Voltage High
P0125    Insufficient Coolant Temperature For Closed Loop Fuel Control
P0131    HO2S Circuit Voltage Low
P0132    HO2S Circuit Voltage High
P0133    HO2S Circuit Slow Response
P0134    HO2S No Activity
P0135    HO2S Heater Circuit Malfunction
P0136    HO2S Circuit Malfunction
P0141    HO2S Heater Circuit Malfunction
P0171    Fuel System Too Lean
P0172    Fuel System Too Rich
P0300    Random Misfire Detected
P0301–P0304    Misfire Cylinders 1–4
P0335    CKP Sensor Circuit Malfunction
P0340    CMP Sensor Circuit Malfunction
P0400    EGR Flow Malfunction
P0420    Catalyst System Efficiency Below Threshold
P0440    EVAP II System Malfunction
P0443    EVAP I System Improper Purge Flow
P0450    EVAP II System Pressure Sensor Malfunction
P0461    Fuel Level Sensor Circuit Performance
P0463    Fuel Level Sensor Circuit Voltage High
P0500    VSS Malfunction
P0505    IAC System Malfunction
P0510    CTP Switch Malfunction
P0601    Internal Control Module Memory Checksum Error
P0603    Internal Control Module KAM Error
P0705 (34)    Transmission Range Switch Circuit Malfunction
P0720 (31)    OSS Malfunction
P0725 (52)    Engine Speed Input Circuit Malfunction
P0741 (29)    TCC Solenoid Performance Or Stuck Off
P0743 (25 Or 26)    TCC Lock-Up Solenoid Electrical
P0751 (27)    Shift Solenoid ‘‘A’’ (No. 1) Performance Or Stuck Off
P0753 (21 Or 22)    Shift Solenoid ‘‘A’’ (No. 1) Electrical
P0756 (28)    Shift Solenoid ‘‘B’’ (No. 2) Performance Or Stuck Off
P0758 (23 Or 24)    Shift Solenoid ‘‘B’’ (No. 2) Electrical
P0771 (29)    TCC Solenoid Performance Or Stuck Off
P0773 (25 Or 26)    TCC Lock-Up Solenoid Electrical
P1408    MDP Sensor Circuit Malfunction
P1410    EVAP II Fuel Tank Pressure Control System Malfunction
P1450    BARO Sensor Circuit Malfunction
P1451    BARO Circuit Performance Problem
P1500    Engine Starter Signal Circuit Malfunction
P1510    ECM Back-Up Power Supply Malfunction
P1530    Ignition Timing Adjustment Switch Circuit Malfunction
P1600    Serial Communication Problem Between ECM & TCM
P1700 (32 Or 33)    TP Signal Input Malfunction
P1705 (34)    ECT Signal Input Malfunction
P1710    Back-Up Signal For Speed Sensor Circuit Malfunction
P1715    PNP Switch Circuit Malfunction
P1875    4WD Low Switch Circuit Malfunction
96–98 SIDEKICK 1.8L ENGINE
P0103    MAF Voltage High
P0111    IAT Circuit Range/Performance
P0121    TP Sensor Circuit Performance Problem
P0122    TP Sensor Circuit Voltage Low
P0123    TP Sensor Voltage High
P0131    HO2S 1 Circuit Voltage Low
P0132    HO2S 1 Circuit Voltage High
P0133    HO2S 1 Circuit Slow Response
P0134    HO2S 1 Circuit No Activity
P0135    HO2S 1 Heater Circuit Malfunction
P0136    HO2S 2 Circuit Malfunction
P0141    HO2S 2 Circuit Malfunction
P0440    EVAP System Malfunction
P0443    EVAP System Improper Purge Flow
P0450    EVAP Pressure Sensor Malfunction
P0451    EVAP Pressure Sensor Range/Performance
P0455    EVAP Leak Detected (Gross Leak)
P0720 (31)    OSS Circuit Malfunction
P0741 (29)    TCC Lock-Up Solenoid Performance Or Stuck Off
P0758 (23 Or 24)    Shift Solenoid ‘‘A’’ (No. 1) Electrical
P0771 (29)    TCC Lock-Up Solenoid Performance Or Stuck Off
P1410    Fuel Tank Pressure Control System Malfunction
P1451    BARO Sensor Circuit Performance Problem
P1705 (51)    ECT Signal Input Malfunction
P1710 (35)    Back-Up Signal For Speed Sensor Circuit Malfunction
P1875 (37)    4WD Low Switch Circuit Malfunction
86–95 SWIFT w/TBI FUEL INJ
13    O2S Circuit
21    TP Sensor Circuit Signal Voltage High
22    TP Sensor Circuit Signal Voltage Low
24    VSS Circuit
25    IAT Sensor Circuit
31    Pressure Sensor Circuit
32    Pressure Sensor Circuit
41    Ignition Fail-Safe Signal Circuit
86–95 SWIFT w/MULTI-POINT FUEL INJ
13    O2S Circuit
24    Speed Sensor Circuit
51    EGR System & Recirculated Exhaust Gas Temperature Sensor Circuit
52    Fuel Injector, California
96–00 SWIFT
P0106    MAP Circuit Performance Problem
P0107    MAP Circuit Voltage Low
P0108    MAP Circuit Voltage High
P0111    IAT Circuit Range/Performance Problem
P0116    Engine Coolant Temperature Circuit Range/Performance Problem
P0121    TP Sensor Circuit Range/Performance Problem
P0123    TP Sensor Circuit Voltage High
P0134    HO2S 1 Circuit No Activity Detected
P0141    HO2S 2 Heater Circuit Malfunction
P0300    Misfire Detected
P0440    EVAP System Malfunction/Gross Leak Detected
P0443    EVAP System Purge Control Valve Circuit Malfunction
P0450    EVAP System Pressure Sensor Malfunction
P0451    EVAP System Pressure Sensor Performance
P0455    EVAP System Malfunction, Large Leak Detected
P0461    Fuel Level Sensor Circuit Performance Problem
P0480    Radiator Fan Control System Malfunction
P0505    ISC System Malfunction
P0506    ISC System RPM Lower Than Expected
P0507    ISC System RPM Higher Than Expected
P0705    Transmission Range Sensor Circuit Malfunction (A/T)
P0720    OSS Circuit Malfunction (A/T)
P0751    Shift Solenoid ‘‘A’’ (No. 1) Performance Or Stuck Open
P0753    Shift Solenoid ‘‘A’’ (No. 1) Electrical (A/T)
P0756    Shift Solenoid ‘‘B’’ (No. 2) Performance Or Stuck Open
P0758    Shift Solenoid ‘‘B’’ (No. 2) Electrical (A/T)
P1250    EFE Heater Circuit Malfunction
P1450    BARO Sensor Voltage High/Low
P1451    BARO Sensor Performance Problem
P1460    Radiator Cooling Fan Control System Malfunction
ESTEEM
P0121    TP Circuit Range/Performance Problem
P0131    HO2S Circuit Voltage Low Sensor 1
P0132    HO2S Circuit Voltage High Sensor 1
P0133    HO2S Circuit Slow Response Sensor 1
P0134    HO2S Circuit No Activity Detected Sensor 1
P0135    HO2S Heater Circuit Malfunction Sensor 1
P0136    HO2S Circuit Malfunction Sensor 2
P0141    HO2S Heater Circuit Malfunction Sensor 2
P0455    EVAP System Leak Detected (Gross Leak)
P0480    Radiator Cooling Fan Control System Malfunction
P0705    Transaxle Range Sensor Switch Circuit Malfunction
P0715    Input Speed Sensor Circuit Malfunction
P0720    Output Speed Sensor Circuit Malfunction
P0725    Engine Speed Input Circuit Malfunction
P0741    TCC Solenoid Performance Or Stuck Off
P0743    TCC Solenoid Electrical
P0745    Pressure Control Solenoid Malfunction
P0751    Shift Solenoid ‘‘A’’ (No. 1) Performance Or Stuck Off
P0756    Shift Solenoid ‘‘B’’ (No. 2) Performance Or Stuck Off
P1700    TP Signal Input Malfunction
P1705    ECT Signal Input Malfunction
P1717    A/T Drive Range Signal Circuit Malfunction
P1895    TCM To ECM Torque Reduction Circuit Malfunction
GRAND VITARA & VITARA
P0111    IAT Sensor Circuit Range/Performance
P0116    ECT Sensor Circuit Range/Performance
P0131    HO2S Circuit Voltage Low Bank 1 Sensor 1
P0132    HO2S Circuit Voltage High Bank 1 Sensor 1
P0133    HO2S Circuit Slow Response Bank 1 Sensor 1
P0134    HO2S No Activity Bank 1 Sensor 1
P0135    HO2S Heater Circuit Malfunction Bank 1 Sensor 1
P0136    HO2S Circuit Malfunction Bank 1 Sensor 2
P0141    HO2S Heater Circuit Malfunction Bank 1 Sensor 2
P0151    HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152    HO2S Heater Circuit High Voltage Bank 2 Sensor 1
P0153    HO2S Circuit Slow Response Bank 2 Sensor 1
P0154    HO2S No Activity Detected Bank 2 Sensor 1
P0155    HO2S Heater Circuit Malfunction Bank 2 Sensor 1
P0156    HO2S Circuit Malfunction Bank 2 Sensor 1
P0161    HO2S Heater Circuit Malfunction Bank 2 Sensor 2
P0171    Fuel System Too Lean (Bank 1)
P0172    Fuel System Too Rich (Bank 1)
P0174    Fuel System Too Lean (Bank 2)
P0175    Fuel System Too Rich (Bank 2)
P0301–P0306    Misfire Cylinders 1–6
P0420    Catalyst System Efficiency Below Threshold (Bank 1)
P0430    Catalyst System Efficiency Below Threshold (Bank 2)
P0455    EVAP Gross Leak Detected
phloop
« Reply #7 on: February 02, 2008, 08:33:59 PM »
Thanks for the info. Another question on the flashes. Will it flash for the first number, pause, and then flash for the second number or will it flash fifty eleven times and I have to try counting all the flashes?
Offline 89tintop
  • 356
« Reply #8 on: February 02, 2008, 09:12:38 PM »
it should flash one after another and then start over and do it again and continue to do it until you turn the key off.
