Need a part # if you could help
  • 1547 Views
welly72
« on: February 04, 2008, 01:00:56 PM »
Ive read around on here about the crown vic rear shocks being used in conjunction with a 2" spacer lift but which front struts should i use. tomorrow im putting on my spacer lift and i need if someone could let me know what year crown vic rears to use and what struts will fit the front.  i want to use new fronts instead of doing the flip cause they need to be replaced anyways.  And a little note ill be buying them at either cheacker or autozone cause thats all we got here in town.  thanks a tone
aaron
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Need a part # if you could help
« Reply #1 on: February 04, 2008, 01:08:59 PM »
The only option for the front is the Old Man Emu front struts. All the other brands availible are all the same length. There was some talk about Calmini coming out with a longer front strut but who knows when that will happen. I used rear shocks for a 93 E150 for my truck - Monroe part # was 32260
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Nicksidekickin
« Reply #2 on: February 04, 2008, 02:14:04 PM »
low range offroad has a strut spacer. Thats what i did on mine and just used the stock struts for now its alot cheaper.
