power!!!!
  • 36 Replies
  • 7784 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: power!!!!
« Reply #30 on: February 11, 2008, 05:48:08 AM »
Instead of using a light bulb or meter, I like to use a buzzer.  You can get one at Auto Zone.  I think they have them that you can plug into your rear lights for a backup buzzer.
Anyway, disonect the battery and place the buzzer between the batt and cable.  If there is a draw the buzzer will sound.  Now you can crawl all over the truck disconnecting and pulling fuses without haveing to look at the light or meter every time.
When you find the right one the buzzer will stop sounding.
Eric
32 MTR's Warn 8000i
big_kountry21
Re: power!!!!
« Reply #31 on: February 11, 2008, 09:20:17 AM »
i was told it has an external regulater
Re: power!!!!
« Reply #32 on: February 11, 2008, 12:14:46 PM »
The clock and ECU will both draw power when the engine is off, you will have to disconnect them for this test.
Offline Armour
  • 360
Re: power!!!!
« Reply #33 on: February 11, 2008, 04:37:54 PM »
The obvious problem is a draw. Judt how big and where? Thats why you need a meter.
big_kountry21
Re: power!!!!
« Reply #34 on: February 11, 2008, 05:00:41 PM »
how muich is a meter?
Offline Armour
  • 360
Re: power!!!!
« Reply #35 on: February 11, 2008, 07:35:12 PM »
You can get just a cheap on for prob 20-30 bucks. You don't know anyone with one?
big_kountry21
Re: power!!!!
« Reply #36 on: February 11, 2008, 08:11:14 PM »
no i dont know anyone with one
