power!!!!
  • 36 Replies
  • 7580 Views
big_kountry21
power!!!!
« on: February 06, 2008, 09:36:10 AM »
ok i bought a new alternator and a new battery and now it's completely dead...... help?????????????????????????????????????????????????????????????????????????
big_kountry21
Re: power!!!!
« Reply #2 on: February 06, 2008, 02:53:18 PM »
its not getting electric
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: power!!!!
« Reply #3 on: February 06, 2008, 08:18:53 PM »
If you can be more specific about your problem it might be easier for us to help. Lets say that you are not getting any lights to turn on at all. Have you checked the ground wires and all the connections at the underhood fuse box? Use a test light and check for power at the fuse box and at the back of the alternator. Start with the easy stuff and let us know.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Armour
  • 360
Re: power!!!!
« Reply #4 on: February 06, 2008, 09:41:30 PM »
Check the main ground for corrosion or bad/ loose connection. But I agree. Start from the beginning and let know what happened!
big_kountry21
Re: power!!!!
« Reply #5 on: February 06, 2008, 10:12:58 PM »
kk here's what i've done so far..... changed alternator, battery, top post terminals. cut and restripped + and - cleaned the terminals and posts with the wire cleaner. checked the conection to the starter and alternator. and thats as far as i've gotten.
Indy
Re: power!!!!
« Reply #6 on: February 07, 2008, 12:19:35 AM »
What's actually dead, the battery, the motor...  what's the actual problem vs. what you've done to fix it.
big_kountry21
Re: power!!!!
« Reply #7 on: February 07, 2008, 06:12:23 AM »
its the bat. draining to the point it wont light up the clock.
Offline derekj
  • 784
Re: power!!!!
« Reply #8 on: February 07, 2008, 06:51:55 AM »
Hook up a small bulb (taillight etc) between the negative battery post and the negative battery terminal. If you have a drain the bulb will light up. Next step is to start pulling fuses to isolate which circuit is causing the draw. Start with the underhood fuse box and then move on to the inside fuse box. The bulb will go out when you pull the fuse of the bad circuit. A wiring diagram will help so you can see what components are on the circuit once you find it.Obviously you want the battery to be charged up before doing this and the car turned off. Let us know.....
Derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
big_kountry21
Re: power!!!!
« Reply #9 on: February 07, 2008, 06:56:07 AM »
kk i'll try that. i just got a brand new bat yesterday
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: power!!!!
« Reply #10 on: February 07, 2008, 07:18:51 AM »
Derek
It's responses like this that set this forum apart.  Excellent.
XL-7 front coils
1.5" rear coil spacers
big_kountry21
Re: power!!!!
« Reply #11 on: February 07, 2008, 07:20:39 AM »
i know ..... i glad that there are guys with the experience enough to help
Offline Armour
  • 360
Re: power!!!!
« Reply #12 on: February 07, 2008, 09:20:05 AM »
yes a wiring diagram would be good cause after you find out what circuit is causing the draw. You then must find out every component on that circuit. Then the fun of disconnecting components the same way to find out which one it is. Electrical is so much fun!
big_kountry21
Re: power!!!!
« Reply #13 on: February 07, 2008, 10:06:57 AM »
since you like electrical sooo much you can come do it..lol.   i am about as bad at electrical as bush is being pres.
Offline Armour
  • 360
Re: power!!!!
« Reply #14 on: February 07, 2008, 01:12:34 PM »
How long does it take to kill the bat? Overnight?
