well i got it running
  • 32 Replies
  • 6409 Views
Offline 92Sidekick4x4
  • 1456
Re: well i got it running
« Reply #15 on: October 24, 2004, 04:53:01 PM »
so it coudl be the o2 censor cuasing me troubles,
wild i will tyr a fuse liek u suggested
  • 1456
« Reply #16 on: October 25, 2004, 03:05:42 PM »
if i replace the O2 censor this shoudl stop the problems?
what does a o2 censor cost?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #17 on: October 25, 2004, 03:11:50 PM »
I know of 3 people that had this exact thing happen to them  on 8 valve trackicks. Thats the fuse it blew and it was the 02. $50 or so to replace if you do it yourself. Double check and see if your o2 has 3 wires comming out of it. 2 wires will be the same color, they are the preheater. Those 2 wires can be cut and the o2 will still work, it just wont have a preheater.
Mike
  • 1456
« Reply #18 on: October 25, 2004, 03:24:31 PM »
wut does the pre- heater do?
  • 1456
« Reply #19 on: October 25, 2004, 03:31:33 PM »
and my check engine light is on now, cars running fine minus the fuse blowage, is this cuz of the censor probly?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #20 on: October 25, 2004, 03:31:46 PM »
It preheats the o2.  :P I dont know when or why! Wild probabally knows though! ;D
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #21 on: October 25, 2004, 03:33:17 PM »
Id just unplug it and see if it happens again, if not then we have a winner! ;)
Mike
  • 1456
« Reply #22 on: October 25, 2004, 03:39:59 PM »
unplug what? the engine light? i hear there is a switch for it, where is it?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #23 on: October 25, 2004, 03:43:31 PM »
No unplug the o2
« Reply #24 on: October 25, 2004, 03:49:28 PM »
Ya. I know
The pre heater or just heater
keeps the O2 sensor at a constant
temp, and gets it there faster so
emissions are lower, especially at
cold startup
;D
  • 1456
« Reply #25 on: October 25, 2004, 06:18:32 PM »
i dont really care about my emmissions :o so i think i will cut the 2 pre-heater wires and see if that works, or acutally ill take out the sensor for a bit and see if it works, if it does, i will cut the wires
« Last Edit: October 25, 2004, 06:19:54 PM by 92Sidekick4x4 »
« Reply #26 on: October 25, 2004, 07:55:22 PM »
Don't cut all of the wires  :o
your trucklet will run badly
and use too much gas, you
can cut the heater wires or
replace it with a 1 wire sensor
from a wrecked car, much cheeper
  • 1456
« Reply #27 on: October 26, 2004, 03:18:15 AM »
ya sorry, i ment cut the 2 pre-heater wires like mike suggested, first im gonan try driving it wiht out the o2 censor in and see if it keep blwoing fuses
« Last Edit: October 26, 2004, 03:19:09 AM by 92Sidekick4x4 »
« Reply #28 on: October 26, 2004, 03:29:25 AM »
Ahh, I missread your post
  • 1456
« Reply #29 on: October 26, 2004, 03:35:22 AM »
you probly coudltn undertsand the post due to my spelling ;D
