well i got it running
  • 32 Replies
  • 6406 Views
Offline 92Sidekick4x4
  • 1456
« on: October 18, 2004, 12:35:17 PM »
ok the trucks running but it keeps blowing a fuse, it is a blue on the closest the the drivers door i think its the fuel injecter fuse? why would it keep blowing on me?
Re: well i got it running
« Reply #1 on: October 18, 2004, 12:46:09 PM »
The only time I blow a fuze is
when the alternator wire touched
and grounded out, the engine would
crank but not start, and it is an instant
pop as soon as the ignition is turned
on the fuse blows
Offline Kreg
  • 795
    • Island 4x4
« Reply #2 on: October 18, 2004, 12:46:43 PM »
Which blue one is it?
The top fuse is for your right headlight.
The bottom one is for your Ignition system and warning indicator lights.
You may have a short circuit somewheres caused from an exposed wire.
Not sure if your CD player would be causing it, but if its hooked to your ignition powerfeed (so it turns off when you shut the truck off) then it might be blowing the fuse too. (though don't quote me on that)
  • 1456
« Reply #3 on: October 18, 2004, 01:50:28 PM »
ok it is the bottom blue one, i just went out for a drive and it hasnt blown again, ill let ya knwo in a bit
« Reply #4 on: October 19, 2004, 12:41:35 AM »
Cool to hear you got it running, what was wrong? Did you find out why you blew the fuse?
  • 1456
« Reply #5 on: October 19, 2004, 02:58:40 AM »
no im not sure why it was blowing fuses, i put a new one in and its not doing it anymore ??? so hopefully it doesnt, im takin it to mechanics today and gonan figure out why it was blowing them.
Offline Mike71
  • 1449
« Reply #6 on: October 19, 2004, 10:37:07 AM »
it might have just been that u had wear fuses..i had that happen a few times with i did HVAC id just get duds
  • 1456
« Reply #7 on: October 19, 2004, 11:33:43 AM »
nah its still blowing fuses, i left it in the mechanics shop at school so i can work on it tommorw, i was reading in my repair manual and apparently the cd player is not on the same fuse as the ign, coil switch (the one that keeps blowing) so i was reading and all the warning lights run on that fuse (ign. coil switch) all my warning lights work but my seat belt one, my teacher said there could be a short in that so that could be the problem, hopefully i will get it figgured it out soon.
  • 1456
« Reply #8 on: October 19, 2004, 11:45:45 AM »
any more suggestions would be nice ;D
  • 1456
« Reply #9 on: October 21, 2004, 10:55:21 AM »
ok, my mechanics teaher thauhgt that it may be my cd player, so i disconected that, it is still blowing the fuses, i checkd all my wires and i didnt see anything abnormal, any other ideas?
Offline jerryp58
  • 449
« Reply #10 on: October 21, 2004, 11:27:13 AM »
Is it the right AMP rated fuse in that socket?
Jerry
« Reply #11 on: October 21, 2004, 02:45:16 PM »
It's an intermitant problem,
check the alternator connection
and get a circuit breaker, that way
it will reset after the short has
got back to normal
  • 1456
« Reply #12 on: October 24, 2004, 10:46:19 AM »
got back to normal
circut breaker?
« Reply #13 on: October 24, 2004, 12:46:55 PM »
Ya, try Autozone in the Fuse
department, it'a a metal fuse
size box with legs just like the
fuse, put it in where the blown
fuse is, now when there is a short,
it breaks the circuit, when it cools
it makes contact and the circuit
will work again, unless there is
a short still, then it will open again.
It's good protection and cost $5.00
Most Semi Trucks have these instead
of fuses, some are manual reset, like
in your house, but just a little pin that
you push back in, the little silver box kind
are automatic reset, really cool and you
will never have a fuse worry again
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #14 on: October 24, 2004, 01:55:52 PM »
Sounds like youve got a bad pre-heater on your O2 sensor. To double check this unplug the O2 and see if it happens again. The check engine will come on though. The repair is to replace the O2.
Mike
